3k cutout
Old Dec 10, 2004 | 11:03 AM
d16efsedan's Avatar
Default 3k cutout
ok i swapped a d16a6 in my 88 dx hatch and ordered a harness for the dpfi to mpfi got it all together and started it up and now i cant rev over 3k and im getting a cel#4 anyone have any idea's or similar things happen...also i changed the dizzy and reset the ecu and started it same thing cel#4 and 3k cutout some please help........
Old Dec 10, 2004 | 11:05 AM
dr_latino999's Avatar
Default Re: 3k cutout (d16efhatch)
It means you're in limp mode, never a good thing.
Which translates probably if you changed the distributor already is that your wiring is wrong. Lesson learned, do wiring yourself
Old Dec 10, 2004 | 11:25 AM
manson's Avatar
Default Re: 3k cutout (dr_latino999)
check all the connections. make sure the pins that were relocated on the ECU are tight. that was my problem once.... loose connection on the pin.
Old Dec 10, 2004 | 11:29 AM
d16efsedan's Avatar
ok ill check them ........
Old Dec 15, 2004 | 12:06 PM
d16efsedan's Avatar
Default Re: 3k cutout (manson)
ok i havent got around to checking anything yet ive been busy but im sure the wiring is messed up does anyone have a clue where i can get all the instructions on the wiring so i can redo it????
Old Dec 19, 2004 | 04:26 PM
d16efsedan's Avatar
ok thanks for all the help i got it fixed finally after six months:D the 2 crank angle sensor wires wasnt even hooked to my ecu dumb mistake by me....thanks a bunch everyone...........
Old Dec 19, 2004 | 05:46 PM
Doing Business's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16efhatch &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for all the help i got it fixed finally after six months:D the 2 crank angle sensor wires wasnt even hooked to my ecu dumb mistake by me....thanks a bunch everyone...........</TD></TR></TABLE>
i was just going to say crank angle sensor. if its broken or not hooked up the car will never no matter what go past 3k
Old Dec 19, 2004 | 08:03 PM
shauniewalnuts's Avatar
Default Re: 3k cutout (Urban Bidnis)
i had the same problem, the person before me did a mpfi swap and fucked the wires up so i ran separate wires right from the dizzy to the ecu and bingo
hammergunner
Oct 19, 2009 08:37 AM
linnhatch
10
Apr 14, 2009 04:34 PM
racingcrx
Sep 10, 2006 05:25 PM
stockmr2
May 24, 2005 08:03 PM
Bserieskllr
May 10, 2005 02:13 PM
