oil pan question?
The girdle from the A3 wont' work as the stock motor uses balancer shafts. The Type S doesn't use those. You won't be able to mix/match between the 2 motors. It's one or the other. The pan will fit just fine though. Hopefully that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsek »</TD></TR><TR><TD CLASS="quote">The girdle from the A3 wont' work as the stock motor uses balancer shafts. The Type S doesn't use those. You won't be able to mix/match between the 2 motors. It's one or the other. The pan will fit just fine though. Hopefully that helps. </TD></TR></TABLE>
you mean the oil pan will fit but the girdle wont?
Frost7177
Aug 30, 2009 09:37 AM
