del sol si brake swap worth doing?
i have a del sol si that im parting out and was wordering what parts i would need to use to swap the brakes over to my 90 lx 4 door?can i swap the complete knuckle up front and the rear trailing arm in the rear out for the sol parts?do i have to swap m/c and the prop valve too?what about parking break should i use the sol cables or modify mine to fit.im lookin for the easiest way out here.....are the front brakes any different?all i could find info on are the ex brakes and del sol vtec brakes.....
Front brakes are going to be a bitch to make work but the rear brakes can be used. I do not if the trailing arms themselves can be used but you can remove the rear assembly and switch it over, pust a PITA to get those bolts off.
I know the front knuckles you cant use. They may not even be any bigger than the brakes you have now. For the front you need DA Knuckles or EF Civic EX Knuckles to get bigger brakes. The rears you can use.
Fronts will probaly be the same size and will not work. They will bolt up but will throw your geometry all outta wack. For the front you want DA or 88-91 EX Knuckles which will have 10.2 rotors and bigger calipers and will bolt on. The rears you only need to swap the brakes and use all your stock suspension pieces.
I just did the front DA brakes, and it was a snap !! $125 for all DA brakes front and rear at the U-PULL-IT.
Going to need CRX SI rear disk brake lines too. May as well buy steel braided lines.
