RC 440 injector, injectors installation quick question
Old Dec 9, 2004 | 03:54 PM
pinche's Avatar
Default RC 440 injector, injectors installation quick question
i have a y8 manifold, need to install the rc 440 injectors, my question is about the rubber seal that the injectors seat up with on the manifold side, not fuel rail side. my oem injectors are not as wide as the RC, so the seal doesnt fit, does anyone know where i can find some seals. or how they fixed this simple problem. Another question is, i have a turbo set up using a boost indexed fuel pressure regulator, i will be using uberdata to run everything. after installing the 440 injectors, i dont use the boost indexed fuel pressure regulator anymore, and just use the stock fpr. thanks any tips are much appreciated. thanks
loren
Old Dec 9, 2004 | 03:59 PM
civiccpedx's Avatar
Default Re: RC 440 injector, injectors installation quick question (pinche)
well you could use a dremel to make the seal larger, or like many others have done, just pushed them in. I would run a search though many people have talked about this topic.
Ldo
Jun 27, 2010 04:55 PM
wesley_925
Apr 11, 2008 08:12 PM
pinche
Dec 9, 2004 08:37 PM
bluedelsol
Sep 8, 2002 03:45 AM
zojirushi
Aug 13, 2002 10:42 AM
