B16 OBD0 CODE 21???
Old Dec 9, 2004 | 03:50 PM
teler86's Avatar
Default B16 OBD0 CODE 21???
I used to have both codes 21 and 23 now I redid some of the wiring and no longer have the code 23. The only thing left is code 21. I am not sure how I could solve this problem, the car does have MSD ignition I dont know if that could be the problem. I Bought the car with the motor already installed, so it makes it more difficult for me to diagnose the probleme. The car did not pass emissions but that is when both codes 21 and 23 were on, could the codes im throwing cause higher emmsions. As always thank you guys for all of your help.
Old Dec 9, 2004 | 04:09 PM
eda6's Avatar
Default Re: B16 OBD0 CODE 21??? (teler86)
code 21 VTEC spool solenoid valve. Check wiring and report back.
Old Dec 9, 2004 | 05:02 PM
hatchi's Avatar
which motor and ecu are you running?? pics would help also
Old Dec 9, 2004 | 05:55 PM
teler86's Avatar
Default Re: B16 OBD0 CODE 21??? (hatchi)
as the title states its a b16 obd0
Old Dec 9, 2004 | 05:56 PM
teler86's Avatar
Default Re: B16 OBD0 CODE 21??? (eda6)
checked the wiring, some wires seem like they could be off but none of them have to do with VTEC
91civichatchCrX
Mar 15, 2006 06:34 PM
ESPTUNING
Mar 28, 2005 07:24 AM
type Gendy
Aug 2, 2003 05:44 PM
