HELP! Electrical gurus please help!
Ok my friends car keeps dying. He just replaced his battery 2 weeks ago and now the car has problems starting after sitting for 14+ hrs. On top of that he turbo timer doesn't count down anymore. We so had him check his wiring over to see if that was the problem, he did and the problem was still there. The battery is brand new and the car is still having problems starting as if something is draining the battery. so i don't know where to look now except the starter,alternator,main relay,or alarm. Any help will be appreciated! thanks in advance!
Does it crank?
Is there spark?
Does the fuel pump prime?
Do your lights work?
If you charge your battery does the car THEN start?
All these are important questions and things we need to know.
Be more detailed.
Is there spark?
Be more detailed.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">Also check alternator and voltage regulator - </TD></TR></TABLE> Also make sure you have 12V to the blue wire on the alt when the key is in the ON position. And check for 12V at the main alt cable. But DIMI is right, we do need those questions answered to narrow down the possabilities...
