Covering O2 sensor hole
It depends. Do you have a welder, or do you know someone who does. I would weld up a plug for it...
If not, i would not mind screwing in a bolt provided that you have enough wall thickness to tread it properly...
fs
fs
Here you go man...
http://www.atpturbo.com/Mercha...e=FTG
This is better than welding it up because you can use a wideband if you need to
You could also just extend the wires on your O2 sensor to reach. A soldering iron, some wire, and a few minutes of your time and the O2 will reach...
Heh, reminds me of when I was installing my header for the first time. I was doing it at a friends house, and it was getting pretty late, and we could not get the o2 sensor out of the stock exhaust manifold, no matter what we tried. I didn't have any of those special types of bolts... so I wrapped a shirt around the exhaust pipe to cover the o2 sensor bung. Pretty ghetto, but it worked for the 2 mile ride home.
But damn, that **** was still pretty loud, but the shirt helped muffle it a little bit.
Cameron k.
Oct 8, 2012 09:41 PM
EJ8chu
Jan 20, 2007 12:53 PM
