Rota Rim question?
Hey should I go with Rota slipstream flat black rims or should I go with the grids the grids look a lot nicer im not to fond of the slipstreams but I need to know wieght differential I really like grids thought!
According to http://www.machiii.net
Slipstreams
Wheel weight: 15x6.5" -12lbs., 15x7" -13lbs., 16" -13.5lbs
Grids
Weight: 15" 12.5lbs 16" 14.5lbs 17" 18.5lbs.
If you wanna see some pics of what they look like, just search in appearance, there is a ton of threads. What color is your car? I like Grids over Slipstreams. Color of wheel depends on color of your car. Good luck.
Slipstreams
Grids
If you like the grids then get those. They only way .5lbs more than the slips in 15in version. You WILL NOT notice such a small difference in weight.
azn_outlaw
Nov 7, 2001 05:51 PM
