Diff Bearings for JDM Type-R
91005-P80-E31 is the bearing you should use
just make sure to use check the clearance of the differential, and use the correct thickness 80mm shim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">WTF is a differential bearing???</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">91005-P80-E31 is the bearing you should use
just make sure to use check the clearance of the differential, and use the correct thickness 80mm shim</TD></TR></TABLE>
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">I remember some versions/years with LSD have tapered bearings. Anyone know which?</TD></TR></TABLE>
the early transmissions came with them
but if your changing bearings, you should just get the sealed bearings anyway
with the tapered bearings, you need to set preload, with the sealed bearings, you just shim the diff to the proper gap
you can install sealed bearings, on the older transmissions that came with the tapered style bearings
y0! You don't got the JDM Diff Bearings yet!?
Sorry, couldn't resist.
mike93eh2
Mar 12, 2007 05:56 PM
cueballsi
Feb 18, 2005 06:21 PM
