how to: install crx hf wiper motor (help anyone?)
Old Dec 8, 2004 | 10:04 PM
ilovemycrx's Avatar
Default how to: install crx hf wiper motor (help anyone?)
i need help on how to install this wiper motor on my crx hf plz post any kind of instruction. TY
Old Dec 8, 2004 | 10:17 PM
doublethink's Avatar
Default Re: how to: install crx hf wiper motor (ilovemycrx)
not to get OT, but why are you replacing, wipers not working?
Old Dec 8, 2004 | 10:20 PM
ilovemycrx's Avatar
Default Re: how to: install crx hf wiper motor (doublethink)
my left wiper doesnt worker but my right side one does, and of course when it rains i need the left side to be working not the right :D not that jdm as to where i need the right side =]
Old Dec 8, 2004 | 10:29 PM
Burlyirishdude's Avatar
that's ok...my wipers stop mid movement if i just do the click one....where you push down on it...and "INT" doesn't even work...hehehe...i'd like to see some info on this.....good Q
Old Dec 9, 2004 | 01:56 AM
ls_vtec_crx's Avatar
lol...mines used to do that too....only the right side would work...but i figured it out...the driver side nut was loose.....
Old Dec 9, 2004 | 02:48 AM
CRXracer88's Avatar
yea same thing here..... the nut was loose
Old Dec 9, 2004 | 06:18 AM
MattP's Avatar
Default Re: (CRXracer88)
Yep, this happened to me, too. Had to replace the arm, since the splines had chewed up the soft metal used for the arm.
Old Dec 9, 2004 | 04:44 PM
ilovemycrx's Avatar
still need help, bump. thx for the input tho
Old Dec 9, 2004 | 05:25 PM
MattP's Avatar
Have you verified that it's not the arm?
If one arm is moving, the motor is okay. Either there is a problem with the splines on the arm or somewhere in the linkage.
Old Dec 9, 2004 | 05:26 PM
xtrafastcivic's Avatar
1. Open the hood and remove the cap nuts and wiper arms.
Note: remove the wiper arms carefully without damaging the hood.
2. Remonve the hood seal and air scoop by prying out their trim clips.
3. Disconnect the 5-P connector from the windshield wiper motor.
4. Remove the four mounting bolts and wiper linkage assembly.
5. remove the wiper harness from the wiper linkage.
6. Seperate the wiper linkage and crank arm at the joint.
7. Remove the three mounting bolts and wiper motor.
8. Install in the reverse order of removal.
this was copied from a helms exactly...
Old Dec 9, 2004 | 05:32 PM
ilovemycrx's Avatar
Default Re: how to: install crx hf wiper motor (XtraFastCRX)
wow thx for the instructions helps a lot
Old Dec 9, 2004 | 05:52 PM
4DRmafia's Avatar
it pretty straight forward if u know what u doin
Old Nov 9, 2015 | 12:25 PM
Crexhustle's Avatar
Default Re: how to: install crx hf wiper motor (help anyone?)
So I have the same problem with my rex 91 si. Left side won't go right side good. Was wondering what went wrong.
Ps new to honda tech. Go easy on me.
Old Nov 9, 2015 | 04:09 PM
whited's Avatar
CRX God
hi
First, since the original post was 11 years ago, you are not going to get a lot of positive responses. See we don't like zombies, and you just raised this thread from the dead. Our first instinct is to shot it and you in the head. Please don't do it again. Just think of us as Rick Grimes, what are we to do with the new guy who just let a zombie into our community?
Second, probably want to create a new thread, cause this one will be locked or trashed. Don't be scared to create new threads, be scared of zombies.
P.S. If you need a 5 post min or some BS to be able to create a thread. Go here and post about your life. https://honda-tech.com/general-discussion-debate-40/
honda_crx_06
Jan 10, 2008 04:39 PM
adeline
Oct 21, 2007 06:36 PM
CRX A4
Feb 18, 2003 07:25 AM
