Little OT: I need a map from you ITR guys.
I'm doing some mild motor work and need a map that is close to suiting my setup just to get it running descent before some dyno time. I'm running poor man's type R w/ around 10.8:1 comp and the usual bolt on's...so I figure a type R map should suit me pretty well. TIA guys.
Sean
Sean
Yeah, I know. I am just in need of a map right now, I have a rom and access to a burner, I just need the map...and I figured some of you guys must have slightly modified once you could send me.
if you find one let me know, I want to play with one ARR map too.
I also got access to a burner and spare chips... just need the Rom.
Bump
I also got access to a burner and spare chips... just need the Rom.Bump
uberdata.com has p72 obd-1 GSR maps you can play with....
http://www.ecimulti.org/uberdata/
just raise the fuel cutoff to 8500, disable the intake manifold butterflys, and richen up the fuel curve for your motor.
It will be hard to find a true ITR map because all of the USDM ITR ECU's are OBD-II...
(not sure about the JDM one's)
Modified by Philly_NBP_R at 10:15 AM 12/9/2004
sewokozak
Engine Management and Tuning
Aug 9, 2018 02:08 PM
rice4life
12
Jan 5, 2005 05:27 PM
