my b20 is overheating!!!! pleez help
Old Dec 8, 2004 | 07:27 PM
b20todaej6's Avatar
Default my b20 is overheating!!!! pleez help
ok i have a b20 vtec and it is overheating, i still have my stock dx radiator but it was never overheating for the 6 months i had the swap in untill now. I noticed that there is sum gunk/ kinda mudd looking stuff inside of my coolant overflow tank, and dont know if thats the problem or not, last time i took it to my mechanic, he said it was the radiator cap seal broke, and he replaced the thermostat, and it ran fine for a bout 2 or 3 weeks, no its overheating again, i felt the top radiator house and its hot with fluid in it . . . . . i dunno whats wrong ?
also on a side not, but distributor cap and rotor have busted twice now? just today on of my plug holes on the cap where the spark plug wire goes in, just cracked off, and i was only running on 3 cylinders, i got the cap and rotor from autozone, the last time it cracked was because the screw that holds the rotor onto the distributor shaft came off and got shot threw the housing of the cap, i think thats might of what happend again? if anyone knows anyting about that problem let me know
thanx a bunch
Old Dec 8, 2004 | 07:53 PM
b20todaej6's Avatar
cmon people, i need some help with this, its very frustrating. the car will stop overheating when i put water in through the radiator cap, if that specifies the issue any . . . . . :/
Old Dec 8, 2004 | 08:07 PM
Mike K's Avatar
Default Re: (b20todaej6)
ok, i'll try and help you on this one. just follow my steps....
1- replace your cap and rotor with OEM honda parts.
2- drain your coolant from your radiator and your block. flush the entire cooling system with a garden hose for a good 3-5 minutes, until it runs clear out the block.
3- have your radiator tested at a reputable radiator shop. have them pressure test it and evaulate the condition of the radiator.
4- (assuming the radiator is ok) fill the system with OEM Honda coolant, or a mix of whatever brand coolant you like.
5- BLEED THE SYSTEM PROPERLY. if you don't know how to do this, keep reading... get a radiator funnel or make one. something that fits in the radiator neck, and holds a reserve of coolant. i use a honda brake fluid bottle with the bottom chopped off, and the neck wrapped slightly in electrical tape to ensure a good seal. then, i fill the system, and keep the brake fluid bottle topped off.
switch the climate control to the hottest setting, and don't turn the blower motor on. just make sure the heater valve is open.
pinch off the hose going to the overflow tank with a set of pinch pliers. then start the car, let it idle and as the bubbles flow, continue to top off the brake fluid bottle. keep doing this until the cooling fan kicks on twice. it could take up to 30 minutes. just be patient.
after doing this, if it still acts up.. i'd look into a headgasket if i were you. i've just seen too many people with "overheating motors", yet they don't know how to properly bleed a cooling system. this is crucial.
if your problems still persist after this, hit me up. we'll go from there.
Old Dec 8, 2004 | 08:51 PM
b20todaej6's Avatar
damn man, thanks for all the help, im gonna have to try this ASAP! but when you were talkin about filling the brake fluid bottle to the top, do u mean just having coolant filled to the top of it or what ?
also how expensive is it to replace a headgasket ?
Old Dec 8, 2004 | 08:55 PM
Mike K's Avatar
basically, the brake fluid bottle is taking up any excess space in the cooling system, and allowing a space for the bubbes to leave the system.
the headgasket labor is like 3 hours or so. the headgasket itself is like $75.00, plus labor, and more coolant.
Old Dec 8, 2004 | 09:09 PM
b20todaej6's Avatar
**** thats alot money, is it hard to change a headgasket yourself ? probably if it takes 3 hours, ok so when i have the brake fluid bottle in the radiator hole with the brake fluid bottle full of coolant, and its done bubbling, how do i get the bottle out of the radiator, w/o coolant spilling everywhere from the bottle . .. . . . ?
Old Dec 8, 2004 | 09:44 PM
Mike K's Avatar
lol.
use a battery filler or ball siphon, or just let it spill, then put the radiator cap on, and rinse the area off with a garden hose.
Old Dec 8, 2004 | 09:49 PM
b20todaej6's Avatar
ok ok, i get what to do now, hey thanx alot for all your input man, i appreciate it alot,
p.s. how have u dominated MILF's?
Old Dec 8, 2004 | 10:06 PM
Mike K's Avatar
back in 2000-01 i did some work for milfhunter.com, and i also did my fair share of picking up 30-40 year old women in the bars/nightclubs of southern florida. there are MANY people who can attest to this. lol.
i don't know why, but i've always gone for milfs. some of my friends bust my *****, but i'll tell you what.... they are WAY better in bed than ANY 18-21 year old chick. think about it. they've been doin' it since you were in elementary school. lol.
Old Dec 8, 2004 | 10:09 PM
b20todaej6's Avatar
i have the exact same feeling about MILFS too, thats nuts, i always go on that website . . . LMAO, my motto is that they are "EXPERIENCED RIDERS!"
Old Dec 8, 2004 | 10:30 PM
Mike K's Avatar
lol. you're nuts. so what parts u got for sale?
Old Dec 8, 2004 | 10:35 PM
b20todaej6's Avatar
just 00 si front seats, and obd2a gsr ecu, stock 99 civic manual mirrors, thats all thats left . . . .
Old Dec 9, 2004 | 10:56 PM
Mike K's Avatar
****. ok. i am looking for toda spec A cams, decent cam gears, and a p28 ecu. thanks anyway.
Old Dec 10, 2004 | 03:53 PM
b20todaej6's Avatar
more problems man, it didnt work, i pmed you check it
Old Dec 10, 2004 | 05:16 PM
b20todaej6's Avatar
bump people, i did what mike k said to do, and its still overheating, anyone have any more suggestions? let me know ASAP !
Old Dec 10, 2004 | 08:43 PM
b20todaej6's Avatar
also today when i was flushing the cooling system with a hose, i put the hose in the top radiator hose, and had the bottom one off, and it wouldnt pump through, so i had to secure it to the hose, so it would build pressure and send flush the system, maybe its cuz i didnt do it the right way now that i think about it . . . . mmmmmm help meeeeeeeeeeeeeeeeeeeeeeeee
Old Dec 11, 2004 | 03:06 PM
b20todaej6's Avatar
good news i think i fixed my overheating, the mugen radiator cap was bunk i think, cuz i put back on my oem radiator cap and it hasnt overheated at all on to and from work, and just driving around town! , but i have a question, the other day my rotor and cap busted, and i was only running on 3 cylinders for like 15 miles, so im wondering if cuz it wasnt firing but still driving, that there is a lot of extra gas in my chamber? or my spark plug got drenched in gas, because it isnt firing up to well, like itll fire, then bog, is this because theres gas in the combustion chamber ? let me know ASAP ! should i change out my plugs or what?
Old Dec 11, 2004 | 03:59 PM
b20todaej6's Avatar
ttt pleez let me know anyone!@
Old Dec 21, 2004 | 11:31 AM
b20todaej6's Avatar
bump cuz its still overheating, i flushed the system and its still overheating, my resivoir tank is really dark fluid? what does that mean, it has gunk in it too ....
hot hatch man
Sep 9, 2015 02:46 AM
Tizight
Sep 6, 2006 10:24 AM
mingbling96
Jul 1, 2005 05:50 PM
92HB_HB
Aug 10, 2004 08:22 PM
citanest
Feb 20, 2002 06:30 AM
