95 ls motor in EK What axles and linkage?
Old Dec 8, 2004 | 06:38 PM
s2kkk's Avatar
Default 95 ls motor in EK What axles and linkage?
Pulling a 95 ls motor in my ek all i need is a ecu, jumper harness, axles, del sol rear mount, What shift linkage do i use and which axles?? Thx
Old Dec 8, 2004 | 06:40 PM
iBear's Avatar
Default Re: 95 ls motor in EK What axles and linkage? (spoon.eg)
any b series will do.
Old Dec 8, 2004 | 07:11 PM
s2kkk's Avatar
the axles will fit in my ek rotors 2? what are all b series the same?
Old Dec 8, 2004 | 07:13 PM
J-Spec EG's Avatar
yeah the axles will be fine , pretty much all of beseries is interchangebale as is d series and so forth.
Old Dec 8, 2004 | 07:15 PM
hybrid_vtec's Avatar
Default Re: 95 ls motor in EK What axles and linkage? (EJellyfish1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJellyfish1 &raquo;</TD></TR><TR><TD CLASS="quote">any b series will do.</TD></TR></TABLE>
Also you may want to use a GSR shift linkage over a B16 linkage! GSR makes the shifter a lil stiffer and not wobble around like the B16 linkage!
Old Dec 8, 2004 | 07:18 PM
JDMFreak's Avatar
Default Re: 95 ls motor in EK What axles and linkage? (hybrid_vtec)
your gonna need gsr axles, i tried Si axles, LS axles and the passenger side, and it keep breakin on me...but for the driver side any b-series axles will....unless O'Reilly screwed me with giving me the wrong axles...and i contact my local shop and they recommand and always use gsr axles for 92-00 swap
oooitzcreeperz
Jun 16, 2008 10:26 AM
ballerchild
May 17, 2007 09:39 PM
dfoxengr
Apr 25, 2005 07:16 PM
BOOSTonHAnD
Jun 10, 2004 09:20 PM
