NEED HELP:Detailed instructions for installing obd 0 to obd 1 jumper harness
Old Dec 8, 2004 | 06:08 PM
rsxtypeS858's Avatar
Default NEED HELP:Detailed instructions for installing obd 0 to obd 1 jumper harness
I have a '91 CRX Si w/'95 D16z6 motor. Need to install "JKOBD" jumper harness to pass bar and get car ref'd. Already installed jumper harness to: vtec solenoid, vtec pressure switch, 4 wire o2, P28 ecu, swapped injectors as well as injector clips. The only thing is....still running '90 si distributor, fuel resistor box, as well a bunch of other loose wires from harness...(SCS"CHECK"), etc.. The car won't start.
Do I have to use '92-'95 distributor and take out/bypass fuel resistor box.
Please help.....Need "How to" detailed instructions for install. Thanks
Old Dec 8, 2004 | 06:15 PM
eda6's Avatar
Default Re: NEED HELP:Detailed instructions for installing obd 0 to obd 1 jumper harness (rsxtypeS858)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxtypeS858 &raquo;</TD></TR><TR><TD CLASS="quote">Do I have to use '92-'95 distributor and take out/bypass fuel resistor box.
Please help.....Need "How to" detailed instructions for install. Thanks</TD></TR></TABLE>
Yes, if you're running high impedance injectors the resistor box must be removed. You also need an obd 1 dizzy. What happened to the instructions from blown90hatch? His harnesses come with detailed instructions.
MMMGIRL
Jan 17, 2012 11:39 AM
pheurton-skeurto
Dec 15, 2009 08:49 AM
damn_import_culture
May 14, 2007 04:10 PM
