B20 experts...need some advice
Old Dec 8, 2004 | 05:50 PM
PAndADc2's Avatar
Default B20 experts...need some advice
i just wanna know if it's worthed to get a b20 block and slap it on my gsr?? or should i just build my stock gsr block bump the compression..im trying to hit 200whp if not closed?? can a stock b20 help me on this ???..my gsr head is getting build right now ?? do u think it's gonna b worth the time and the money???
Old Dec 8, 2004 | 06:09 PM
jdmsijdm's Avatar
instead of spending the money on the b20, i would use that money and get your b18c block bored to 81.5 or 82mm and get aftermarket pistons.
Old Dec 31, 2004 | 07:46 PM
GWInquisitor14's Avatar
Default Re: (jdmsijdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsijdm &raquo;</TD></TR><TR><TD CLASS="quote">instead of spending the money on the b20, i would use that money and get your b18c block bored to 81.5 or 82mm and get aftermarket pistons. </TD></TR></TABLE>
Do that and you will probably crack the sleves if you up the compression
Old Jan 3, 2005 | 06:21 AM
jdmsijdm's Avatar
.5 over will crack sleeves??
Old Jan 6, 2005 | 06:14 PM
Default Re: (GWInquisitor14)
oh sorry i read that wrong, i read it as B20 bored over
Old Jan 6, 2005 | 06:38 PM
jdmsijdm's Avatar
how could "b18c block bored over to 82mm" be confused with b20?
blue skunk2's Avatar
Default Re: B20 experts...need some advice (PAndADc2)
I would build up the gsr block instead of getting the b20 block unless your sleeving the b20 because the b20 has the weakest sleeves in it and can crack easily. But the cheaper route would be build up the gsr block beacuse you don't have to sleeve a vtec block unless your running real high compression like 13:1 or
high boost like 20-25psi. The good advantage to vtec blocks are that they have oil
squirters in each of the cylinders to help cool them down under extreme pressure.
Hopefully this will help you out.
Old Jan 6, 2005 | 07:28 PM
Plugs's Avatar
Default Re: B20 experts...need some advice (blue skunk2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue skunk2 &raquo;</TD></TR><TR><TD CLASS="quote"> I would build up the gsr block instead of getting the b20 block unless your sleeving the b20 because the b20 has the weakest sleeves in it .
As he said it. I run a Mildly Built B20Vtec. And I get worried all the time aboput the Walls cracking.
Old Jan 6, 2005 | 09:24 PM
s2kc's's Avatar
a b20 wont handle good boost??
Old Jan 6, 2005 | 09:28 PM
Supahr_Ed's Avatar
i run a B20, and the only reason im worried about the walls cracking, is because of the people that i talk to online. I ran 12k on it in just about a year, no problems.
I would love a built GSR but if you only have about $500 to spend on the block, a B20 would be my first choice. $500-700 for a longblock B20B is a pretty good deal to me. If you got the money, just build the GSR...i would, just for the high rev.
Old Jan 6, 2005 | 09:34 PM
ek9vboi2's Avatar
b20b is low compression. how low... 8:8 with stock head or ls head, not sure what it would be with a vtec head on it. b20z has a higher compression.
im boosting a b20b stright up and no cracked sleeves yet. i guess its just the b20z that seem to be cracking. maybe its because of the compression...piston.
Lsweez
Dec 7, 2007 05:39 PM
Mugen_DC2R
May 27, 2006 07:25 PM
swaplighter
Jan 26, 2004 07:08 PM
TypeR0149
Aug 22, 2001 12:32 AM
