92-95 Civic Suspension on a 88-91 CRX
Old Jan 2, 2002 | 12:55 PM
marty's Avatar
Default 92-95 Civic Suspension on a 88-91 CRX
who says it will fit and who says no. and explain why.
Old Jan 2, 2002 | 12:58 PM
Todd00's Avatar
I said I don't want a title!
Default Re: 92-95 Civic Suspension on a 88-91 CRX (MugenEF7)
It should fit perfectly in the rear. You'll need to use the 92-95 forks in the front to get it to work from what I hear. If will raise the front of the car up, but this shouldn't be an issue if you use coilovers.
Old Jan 2, 2002 | 01:03 PM
june's Avatar
well i know the rear with the disc brakes works cause i did a rear wheel disc swap on a 1990 si from a 94 delsol si. I didn't try to swap out the front though so i couldn't tell you i it works.
Later june
Old Jan 2, 2002 | 01:20 PM
McD's Avatar
McD
Default Re: 92-95 Civic Suspension on a 88-91 CRX (civicefhatchback)
What's better about the 92-95 suspension?
Old Jan 2, 2002 | 01:23 PM
marty's Avatar
Default Re: 92-95 Civic Suspension on a 88-91 CRX (amethistco)
got you all on one thing.
88's have rear ball jointed suspension,89-91 have forked suspension.
i have an 88. ill go with the suspension from a jdm EG
thanks everyone.
Old Jan 2, 2002 | 01:37 PM
Todd00's Avatar
thanks everyone.
Even better...go with the suspension from a DC2R.
Old Jan 2, 2002 | 01:53 PM
Mugen Dom's Avatar
u can use the itr suspension i have an 88 also but u need the front forks to mount the stuts teh rear should bolt on no problem
Old Jan 2, 2002 | 02:27 PM
marty's Avatar
Default Re: 92-95 Civic Suspension on a 88-91 CRX (jdmB18hatch)
i have the forks from a JDM EG in the front.
since i was looking at the JDM EG suspension, the rear is a bushing.
since the JDM EG and the DC2 offer the same rear, im good to go.
thanks everyone.
Old Jan 2, 2002 | 02:43 PM
Eggman's Avatar
for the rears you need the correct lca. it depends if you get jdm EG or usdm EG rear struts.
for the front you need the EG forks, because the EG struts are wider then the EF ones. i think this is where the upgrade takes place. wider struts mean better struts. some jdm aftermarket struts come wider then stock, for a better performance.
i thought you had vision coilovers? i'm i mistaken? wanna sell them?
Old Jan 2, 2002 | 02:59 PM
wldctrx's Avatar
Default Re: 92-95 Civic Suspension on a 88-91 CRX (Eggman)
i swapped in the rear trailing arms from a 92 teg LS and used my stock crx lca's. aren't the DC ones longer?
Old Jan 2, 2002 | 03:21 PM
marty's Avatar
Default Re: 92-95 Civic Suspension on a 88-91 CRX (wldctrx)
the DC ones are longer.. but i just need to make it fit the shocks from a DC2
Old Jan 3, 2002 | 04:50 PM
Bnjmn's Avatar
Like someone before asked- what is better about the EG suspension? Just the wider struts? Does anything get messed up besides ride height? It seems like changing the ride height would mess up the geometry?
Supposing that I do put on EG parts- can I use things like the Competition Engineering control arms and the EG version of the Z10 crossmember?
Thanks
Ben
boostngsr
Dec 12, 2004 02:19 PM
Ace00
Jun 25, 2004 04:23 PM
ogawa_jiei
Mar 28, 2004 02:36 PM
Robb
Dec 29, 2003 09:31 AM
