EK Civic Cluster in a EG.
Does anyone know where I can find a DIY for this. I tried searching and it didnt turn up anything useful. I know some of you have done this, I wanted to know How hard is it? and is the end result as good as stock? any help would be appreciated. Thanks.
Munkyw3rkz.webs.com
as you can see here Neatkidd installed teh CTR cluster in.....you have to redo the wiring to work! also triming of the bezel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake »</TD></TR><TR><TD CLASS="quote">[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNDMyOTcwNnM0MTNkZmQzMXk1NDE%3D.jpg[img]
as you can see here Neatkidd installed teh CTR cluster in.....you have to redo the wiring to work! also triming of the bezel</TD></TR></TABLE>
yea I know thats where the idea came from... the wiring is what I have a question about. I really could use a DIY on this one. I'm trying to put a Civic Si Cluster in my 1994 Dx (5spd) Coupe.
Munkyw3rkz.webs.com
this is from Nick (Beatkidd) from what he did to his, i was goign to do the same with my CTR cluster......
the first color is the base the second is the stripe eg..black/blue.= black wire with a blue stripe...some whire have grey dots aswell but if you follow the wiring to the light on the actuall cluster you be able to figure which is what
B2 ground.....black to black
B3 Trunk......Blue/Black...... to green
B4 Hazard/Rturn green/yellow to green yellow
B5 E-brake..... green/red to green red
B6 Seat belt....Red/Blue to blue/wht
B10 Fuel gauge....Yellow/black to yellow/white
B11 Tach..........Blue/white to blue/white
B12 Temp.........Yellow green to yellow/green
b15 VSS..........Black/white to black/yellow
B16 Charge.......White/Blue to white blue
C3 oil...........Yellow/Red to yellow/red
C4 Ignition .....Yellow to yellow
C5 engine check...green/orange to green orange
C6 High Beam......red/green to red/green
C7 Hazard/Lturn...Green/red to green/blue
C8 Tach input.....Blue to blue
C12 Dimmer.........red to red
C13 guage lights Red/black to red/black
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake »</TD></TR><TR><TD CLASS="quote">this is from Nick (Beatkidd) from what he did to his, i was goign to do the same with my CTR cluster......
C13 guage lights Red/black to red/black</TD></TR></TABLE>
awesome...but which one is which? I asume the above is EG color to EK color? or is it vice versa?
from the way it's written, I assume the letter/number (ie. B2) positions are the positions of the plugs on the EK cluster, and the wire color codes (ie. black/blue) is the wiring of your EG car.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">from the way it's written, I assume the letter/number (ie. B2) positions are the positions of the plugs on the EK cluster, and the wire color codes (ie. black/blue) is the wiring of your EG car.</TD></TR></TABLE>
yes
yes
andy8ass
Feb 8, 2013 01:23 AM
Stins~b20VTEC
Nov 12, 2006 07:00 PM
Sask_Tuner
Aug 4, 2004 12:40 PM
