Propportioning valve
Old Dec 8, 2004 | 02:12 PM
a11mtrhatch's Avatar
Default Propportioning valve
hey guys i am new to the forum and i had a quick question. i did the the 90-93 integra brake swap and i put in the integra master and booster but not the proportioning valve. so i had to make some new lines and they got mixed up some how. so if anyone has a diagram of what lines go where on the proportioning valve that would be great. i already search the archived stuff but no luck. thanks in advance
Old Dec 8, 2004 | 02:25 PM
EL Vap133's Avatar
Default Re: Propportioning valve (a11mtrhatch)
What car do you have, did you add the rear disc brakes too?
Old Dec 9, 2004 | 10:15 AM
Default Re: Propportioning valve (EL Vap133)
i have a 90 hatch and i did the front and rear disc brake conversion from a 90-93 integra.
Old Dec 9, 2004 | 11:19 AM
dr_latino999's Avatar
Old Dec 9, 2004 | 06:53 PM
Default Re: Propportioning valve (dr_latino999)
thanks i think this will help
ryan
Old Dec 9, 2004 | 07:05 PM
B2FiNiTY's Avatar
Why did you have to mess with the lines?
Old Dec 10, 2004 | 05:19 PM
Default Re: Propportioning valve (B2FiNiTY)
well the acura master cylinder has a bigger fitting so i THOUGHT it would just be easist to make a new line. did that problem solved. then i got stainless brake lines and another fitting got stripped because i was using a regular 10mm open end wrench. and some how in this mess the wrong line got clipped. i started trying to bleed the brakes and no presure just a big puddle of brake fluid under the car.
Catch
Apr 8, 2011 01:01 AM
HamiltonRex
Dec 19, 2010 08:10 AM
88 EF Hatch
12
May 5, 2010 11:51 PM
nordic97mist
Aug 4, 2009 06:49 AM
Jeff_B
Welding / Fabrication
Feb 22, 2005 04:04 PM
