Converting H22A to OBD II. Do I need to replace the Knock sensor?
Old Dec 8, 2004 | 09:57 AM
Boarderx192's Avatar
Default Converting H22A to OBD II. Do I need to replace the Knock sensor?
Do I need to replace the knock sensor? I have everything else that I need except the knock sensor and I dont know where I can find a used one at. Is there a way I can use the JDM one? Or does anyone have and OBD II knock sensor?
Old Dec 8, 2004 | 10:47 AM
gerhard's Avatar
Default Re: Converting H22A to OBD II. Do I need to replace the Knock sensor? (Boarderx192)
The answer to that is: Yes.
If no other reason than the connector for the OBD-I knock sensor is different than on the OBD-II models.
(I just ran into that this weekend myself.)
Old Dec 8, 2004 | 01:06 PM
Eddiebx's Avatar
actually they are all the same thing, just the connectors are differnent, so if you have the proper mating connector, just go and hook up whatever you have.
Old Dec 8, 2004 | 08:13 PM
Default Re: (Eddiebx)
Where can I get the proper mating conector?
Old Dec 8, 2004 | 09:04 PM
ludegetsmwet's Avatar
Default Re: (Boarderx192)
look around junk yards autozone ebay, do some research and you'll find one
Old Dec 9, 2004 | 03:33 AM
Keith's Avatar
Default Re: (ludegetsmwet)
It's one wire... just solder it on.
Keith
der3k
Apr 19, 2014 11:21 AM
97blacklude
Jan 31, 2009 09:56 AM
Leviata-N
Mar 13, 2006 11:36 AM
