Hondata investigates K20Z '05 RSX
Old Dec 8, 2004 | 09:48 AM
303TopSecret's Avatar
Default Hondata investigates K20Z '05 RSX
pretty intresting info, thought i'de share it. follow link:
http://www.hondata.com/dynok20-05rsx.html
Old Dec 8, 2004 | 10:27 AM
kseriesDC5's Avatar
Default Re: Hondata investigates K20Z '05 RSX (303TopSecret)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 303TopSecret &raquo;</TD></TR><TR><TD CLASS="quote">pretty intresting info, thought i'de share it. follow link:
http://www.hondata.com/dynok20-05rsx.html</TD></TR></TABLE>
whoa interesting indeed. thanks for the post
Old Dec 8, 2004 | 10:41 AM
THE GAME IS THICK's Avatar
pretty cool. they stated that the speedometer was not working during the test... makes you wonder... good info
Old Dec 8, 2004 | 10:47 AM
DJ_SaNdOz's Avatar
Default Re: Hondata investigates K20Z '05 RSX (HYPHYBOY)
Nice
Old Dec 8, 2004 | 12:11 PM
johnkimble's Avatar
wow, hondata really hopped on the 05 rsx's quickly, great numbers as well. speedo not working on a car with 1100 miles on it is GANGSTER!
Old Dec 8, 2004 | 12:43 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (johnkimble)
Rediculous gains, there .
Old Dec 9, 2004 | 09:51 AM
krystar's Avatar
still the problem is that 05 owners will have to buy a brand new ecu. like it or not. tuff for them.
Old Dec 9, 2004 | 09:57 AM
EPic's Avatar
Default Re: (krystar)
wow didn't know they have a new engine code for the 05' RSX -- k20Z
Old Dec 9, 2004 | 12:55 PM
Q.S.'s Avatar
Default Re: (EPic)
w00t!
Old Dec 9, 2004 | 01:27 PM
stevel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYPHYBOY &raquo;</TD></TR><TR><TD CLASS="quote">pretty cool. they stated that the speedometer was not working during the test... makes you wonder... good info</TD></TR></TABLE>
what makes you wonder? if you read it they had to wire in an 04 ecu cause the 05 ecu is different. that's why the speedo didn't work. they didn't just plug in the 04 ecu with K-Pro, they had to wire it in. read up!
s
Old Dec 9, 2004 | 07:27 PM
Default Re: Hondata investigates K20Z '05 RSX (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">
s</TD></TR></TABLE>
no **** ... it makes you wonder why the speedo doesnt work... well me at least. why dont you read up and quit trying to find ways to flame on people f*cktard
HYPHY
Old Dec 9, 2004 | 07:41 PM
PhreeStyleHB's Avatar
bling bling!
Old Dec 9, 2004 | 07:48 PM
Options's Avatar
All Secrets Known
I need a new 05 RSX. Nuff said.
Old Dec 10, 2004 | 04:23 AM
Mr Boston's Avatar
Default Re: Hondata investigates K20Z '05 RSX (99 EK)
Wow amazing
Old Dec 10, 2004 | 06:18 AM
stevel's Avatar
HYPHY</TD></TR></TABLE>
woah, panties in a bunch there? I wasn't flaming anybody. I asked a question and then said read up. That's far from flaming anyone. And it says right in the friggin article what the issue with the speedo was. It did work just read wrong. The VSS is on a different shaft that spins at a higher speed. Damn, chill out.
s
Old Dec 10, 2004 | 06:35 AM
taikahn's Avatar
Great stuff. Subscribed.
Old Dec 10, 2004 | 11:09 AM
Stupid flanders, you're a genius!
Old Dec 10, 2004 | 11:01 PM
ecsahs3's Avatar
gotta love hondata
Old Dec 12, 2004 | 12:41 PM
krystar's Avatar
it's gonna be a tuff job for em. either they make the ppl buy a 02-04 ECU and sell em a harness. or tehy're going to have to try to crack the new ecu which will be another year. lotta time to invest.
Old Dec 25, 2004 | 04:15 PM
PrettyLude's Avatar
They will try to convert the new ecu but It is built differently and the maps are stored differently. If it's not cost effective then they most likely will make an adapter harness and you can use the 02-04 ecu(kpro).
Old Dec 25, 2004 | 04:29 PM
chunky's Avatar
soo it looks like the k20z is a type-r in sheep's clothing?
they did say that the k20z ecu has a faster processor in it, I wonder how much of a difference that makes.
Old Dec 26, 2004 | 09:38 PM
Westrock2000's Avatar
Default Re: (chunky)
Geez, thats alot of changes actually. I thought it was going to be more like where they just changed the headlight ands bumpers like in the 98+ Integras....but they went all out it looks.
Old Dec 27, 2004 | 05:13 AM
krystar's Avatar
the main issue is that the K20Z1 ECU does not use EPROM to store the maps. they're burned directly on ROM. So there's not much chance of flashing that....unless they somehow put a new memory unit into the ECU. it won't be easy.
k20z1 is almost a typeR. it does not have the DC5R's pistons nor lsd. it's a K20a2 + typeR cams + new ecu + typeR final drive
Old Dec 27, 2004 | 07:50 AM
Revolution2zz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystar &raquo;</TD></TR><TR><TD CLASS="quote">the main issue is that the K20Z1 ECU does not use EPROM to store the maps. they're burned directly on ROM. So there's not much chance of flashing that....unless they somehow put a new memory unit into the ECU. it won't be easy.
k20z1 is almost a typeR. it does not have the DC5R's pistons nor lsd. it's a K20a2 + typeR cams + new ecu + typeR final drive</TD></TR></TABLE>
The 05 IS flashed base just like the 02-04. Even Hondata says so themselves in the link.
"The 05 ECU uses a newer processor than the 02-04 ECU. It is not eprom based but flash based like the 04" So it is flashable, they just gotta come up with a program.
Old Jan 11, 2005 | 03:42 PM
H22EKHATCH's Avatar
I wonder if any companies have plans on creating a plug and play crossover harness
Hasport? Skunk2? anyone
