Any DA's on here with 4 lug ITR brakes?
Old Dec 8, 2004 | 06:58 AM
HONDA_TYPE_R's Avatar
Default Any DA's on here with 4 lug ITR brakes?
I am thinking about doing this or the 5-lug I can't make up my mind. The 5 lug would be mostly for looks, the 4-lug would be just for the upgrade. I'm already running an ITR suspension setup, minus the ITR sway bar(s). Would I need to modify my hubs like I would on the 5-lug? Any answers would be greatly appreciated.
Old Dec 8, 2004 | 07:17 AM
slowkaos's Avatar
Default Re: Any DA's on here with 4 lug ITR brakes? (HONDA_TYPE_R)
I'm confused. Don't integra's already have 4lugs? I thought the only conversion you could do is to swap to a 5lug setup!?!?(Correct me if I'm wrong.)
Old Dec 8, 2004 | 07:23 AM
dFreezy's Avatar
Default Re: Any DA's on here with 4 lug ITR brakes? (slwkaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slwkaos &raquo;</TD></TR><TR><TD CLASS="quote">I'm confused. Don't integra's already have 4lugs? I thought the only conversion you could do is to swap to a 5lug setup!?!?(Correct me if I'm wrong.)</TD></TR></TABLE>96 itr's had a 4x114.3 lug pattern
Old Dec 8, 2004 | 08:31 AM
slowkaos's Avatar
Default Re: Any DA's on here with 4 lug ITR brakes? (dFreezy)
Sweet.....Thanks man. lol I learn something new everyday.
Old Dec 8, 2004 | 08:53 AM
riceball777's Avatar
i have the itr 11 inche rotors and calipers on my da
i had the rotors redrilled to 4x100
Old Dec 8, 2004 | 09:35 AM
SwedBoy2999's Avatar
To do both of them you need to have the front machined to fit. You need to use the DA knuckles since the ITR have a little bit different geometry.
This site will help...
http://battlecat.8m.com/ITR%20...A.htm
On a side note if you don't mind. Did you run into any problems putting in your ITR suspension. Mines coming in the mail today, i'm pretty pumped. I searched alot and there is not that many people that have it on DA's. Do you know if the rear ITR sway bar will fit? How do you like the ride with the ITR HA's? Thanx a bunch!
You can just PM me about this if you don't mind or post, but i'm not jacking the thread.
Old Dec 8, 2004 | 11:35 AM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: Any DA's on here with 4 lug ITR brakes? (SwedBoy2999)
I was gonna post that site RyanK is a DA god
Old Dec 9, 2004 | 06:53 AM
Default Re: Any DA's on here with 4 lug ITR brakes? (theSYNDICATE)
Damnit...I was hoping I wouldn't have to do any machining.
SwedBoy2999-PMing you...
riceball777-How long have you had the re-drilled rotors for? I wouldn't mind doing this, but I'm afraid of them warping or being weakened from being cold-drilled instead of cast in.
Old Dec 9, 2004 | 07:07 AM
math labs's Avatar
On a side note, RyanK is now doing 240 work, check out his 5 lug conversion for a 240 here: http://www.tougefriends.com haha this guy just doesnt stop
Old Dec 10, 2004 | 06:16 AM
Default Re: (math labs)
I've read his article...I think I have it saved. Just curious, can I run the ITR front sway bar? Thanks for the help guys!
Old Oct 4, 2005 | 08:22 AM
Methane2k2's Avatar
dope might do this on my car...
Old Oct 4, 2005 | 08:50 AM
BlackLudeSi's Avatar
Default Re: Any DA's on here with 4 lug ITR brakes? (Methane2k2)
Thats a great link! Having visions of five lug ITR wheels on my championship white DA...
Old Oct 5, 2005 | 09:07 AM
Methane2k2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwedBoy2999 &raquo;</TD></TR><TR><TD CLASS="quote">To do both of them you need to have the front machined to fit. You need to use the DA knuckles since the ITR have a little bit different geometry.
You can just PM me about this if you don't mind or post, but i'm not jacking the thread.</TD></TR></TABLE>
Awesome Info.... This also goes to the 4X114 lug pattern right?
Old Oct 5, 2005 | 09:25 AM
temp's Avatar
i dont recommend it because finding good wheels in that offset sucks ***
Old Sep 21, 2006 | 11:25 AM
DA9Rood's Avatar
Default Re: Any DA's on here with 4 lug ITR brakes? (riceball777)
did you just bolt the calipers and rotors up to your DA? after drilling them to fit 4x100
KIWI
Sep 15, 2004 12:21 PM
ozzyman
Mar 8, 2004 07:58 PM
Filliam H. Muffman
Mar 3, 2004 05:19 PM
inzaneN1
Feb 8, 2004 10:36 AM
