suspension techniquie sway bar
I have a front adn rear sway bar for a eg .. a friend forgot to take off the hardware when he traded his in. I can not find there web site anywhere. where can I find hardware the rear i just need the l brakets coming off the rear lca adn the front I need all of it. front is the 1" rear is 3/4"
Thanks
Thanks
you have to order those from a vendor; suspension techniques does not sell components to the public (or at least that's what they told me when i tried to order replacement bushings for the rear endlinks). look around.
You have a 3/4" rear sway. ST offers two different bushings with that, depending on your bolt spacing. There is a 2.0-2.5" bolt spacing and a 2.5-3.0" one. For their endlinks, you need to know the length from mount to mount, and they have replacements in .5" increments from 2-6".
Unfortunately their application list doesn't say what every car needs.
Their website is http://www.stracing.com
If you know which parts to order, I can get them for you.
For the front, it probably has all kinds of special hardware, as my front kit I put on my integra had spacer blocks.
