95 GSR clutch "chatter" in first - need suggestions and cause
Old Dec 8, 2004 | 05:10 AM
wreckedmyteg's Avatar
Default 95 GSR clutch "chatter" in first - need suggestions and cause
I've got a 95 GSR I just started driving for the winter. Just recently (last two or three days) the clutch has developed chatter letting it out in first (take off from dead stop). Any ideas what could cause this?
You can feel it in the pedal, like it's kinda sticking. I assume the clutch has worn down to the rivets and that's why it's so grabby like.
It only does it in first gear. Every other gear shifts fine and the clutch engages smooth. Also, it looks like the master cylinder (clutch) is leaking, but I recently filled and bled it. I also just dumped in 2.3 qts of GM synchromesh. That's about the time this started.
If it was the clutch disc (wearing down to the rivets), wouldn't it just slip, or would it cause the symptoms I've listed? Also, at high RPM's, the car seems to shake a little left to right. That also started at the same time.
Any help is appreciated. I don't want to tear down the winter beater.
Old Dec 8, 2004 | 06:32 AM
hawjboi's Avatar
Default Re: 95 GSR clutch "chatter" in first - need suggestions and cause (wreckedmyteg)
is the clutch stock or aftermarket.??
Old Dec 8, 2004 | 06:35 AM
HONDA RR's Avatar
You most likely need a new clutch. Just remove the trans and get a performance clutch kit with the flywheel.
Old Dec 8, 2004 | 08:30 AM
blk_db2's Avatar
Default Re: 95 GSR clutch "chatter" in first - need suggestions and cause (MITSUBA)
you need your flywheel resurfaced..... you got what they call hot spots on it and it causes that chattering.... had that on my old civic, it would cause the dash to shake....
Old Dec 8, 2004 | 07:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">You most likely need a new clutch. Just remove the trans and get a performance clutch kit with the flywheel. </TD></TR></TABLE>
Yea, I like that..."JUST" remove the trans and get a performance clutch kit with flywheel...
Am I "JUST" supposed to **** out a new clutch kit? I don't think my sphincter gets that big.
Any body think it could be an inner CV joint? And if it is the flywheel, how would it happen all of a sudden like?
Old Dec 8, 2004 | 07:32 PM
WhiteGSR95's Avatar
the chattering could be a few things
contaminated disk (which is like the most common)
ure release fingers could be bad
warped disk or pressure plate
or a bad fork
Old Dec 9, 2004 | 04:04 AM
Default Re: (WhiteGSR95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteGSR95 &raquo;</TD></TR><TR><TD CLASS="quote">the chattering could be a few things
or a bad fork</TD></TR></TABLE>
I did spill a bunch of oil on the motor when filling the tranny. The damn funnel tipped over. I wouldn't of thought it could seep into the bell housing and all over the clutch though. Guess it's possible.
If that is the case, will it wear away eventually and go back to normal?
Mikeyb918
Oct 31, 2012 05:55 PM
dsmgurrl
Sep 18, 2008 05:14 PM
Telix
Sep 6, 2006 04:41 PM
pskkd930
May 31, 2006 10:30 AM
redteg1
Aug 31, 2001 11:15 AM
