problem removing rear seats...
okay, before anyone starts bickering let me explain my motives...i'm not removing them for weight reduction or style, but frankly because i'm sick and tired of driving all my hammered friends home every ****** weekend--now, with that said, here's the problem:
i was following the haynes mannual and everything was going as planned until it told me to remove these two bolts which hold the seats to the body (apparently located under a lach)...i found the lach--but no bolts...maybe i can't find them because i'm blind but if anyone has pics or has came upon a tutorial on how to do this, please do send--i'de appreciate it immensly....time's running out 'till this friday
ps...my car's a 95 integra ls
i just removed my seats the other day. from what i recall if someone never took mines out before. their is only 1 10mm bolt holding it down and to remove u must flip it forward then pull up or somthing in that area. but make sure u flip it forward thats key! GL
First you remove the carpet tabs on the back of the seats (the part that folds down). Then on each side of the seat (next to the side panels) there is a plastic clip. Remove both of them. With the seats still folded down, push one of the seats from the center towards the side panel. Then you can lift up and pull the top portion of the seat out of your way. Do the same for the other side of the seat. Now your left with the bottom portion of the seat. There is a 10mm bolt at the back center of the seat near the seatbelts. Remove the bolt and pull up on the seats and slide back. The seats should be able to come out. Then your done.
RuskeR
Nov 28, 2004 05:26 PM
