Fuel Pressure on HF engine?
Old Dec 7, 2004 | 08:56 PM
JohnnieChimpo's Avatar
Default Fuel Pressure on HF engine?
While installing a GSR engine in my HF I couldn't get the fuel lines to work because the HF has a huge return line and the GSR regulator has a small return line.
To "cure" problem I installed the HF regulator on the GSR.
Have I screwed up the fuel pressure? I don't have a gauge.
Old Dec 8, 2004 | 08:16 AM
Default Re: Fuel Pressure on HF engine? (JohnnieChimpo)
ttt
Old Dec 8, 2004 | 08:20 AM
HT Chaplain's Avatar
Loved
I put a b18c in mine and just hose clamped it tight.
Old Dec 8, 2004 | 03:11 PM
Default Re: Fuel Pressure on HF engine? (HT Chaplin)
THe HF regulator bolted right on and allowed me to use the HF fuel return hose and a normal clamp, like what came on it from the factory.
It all looks OEM except I don't know the pressure between the two.
Old Dec 8, 2004 | 03:54 PM
SexyAzNMami's Avatar
I did the same thing too. Since the hF line is way bigger than the gsr. I hosed a clamp down on it and make sure it doesn't leak. lol As long as it's not dripping, it's all good. Enjoy the horsepower
Old Dec 8, 2004 | 10:25 PM
Default Re: Fuel Pressure on HF engine? (SexyAzNMami)
That's cool.
Do you guys happen to know the fuel pressure of the HF and the GSR?
Old Dec 8, 2004 | 10:31 PM
Burlyirishdude's Avatar
I used the same pump and lines and filter assembly from the HF into a B16a.... I had to twist the line end to make the bend fit the Fuel rail end...but **** it worked....I don't think the Lines will do that much damage....keep us posted....i'm interested....you got my mind running..
JDubya
Welding / Fabrication
14
Jun 5, 2008 08:21 AM
jessevtec
Aug 10, 2006 05:11 AM
agreziv89ef-8
May 10, 2004 05:57 PM
cavakilla
Mar 22, 2004 05:59 PM
