milky coolant
Old Dec 7, 2004 | 08:18 PM
limpy's Avatar
Default milky coolant
my buddy has a 92-95 lude with the h23a1 motor in it. the oil and coolant is mixing somewhere cause both the coolant and oil are milky and almost the consistancy of elmers wood glue. i was thinking maybee the oil cooler was leaking cause that is the only place that i can think of that oil and coolant come in contact. any advice or previous experiences with this would be awsome. thanx in advance.
Old Dec 7, 2004 | 08:24 PM
94svtec's Avatar
Default Re: milky coolant (limpy)
From what you are describing it could be a blown head gasket. I know of one way to check for this. Turn the car on with the radiator cap off. If you can see bubbles or if the coolant has oil in it then more than likely the headgasket is blown. Does the car overheat? Hope this helps. One more way to check is if you rent or go to a mechanic who has a device that has a blue dye in it. The device is placed where the radiator cap is and by squeezing the bulb on the device the dye is mixed with the vapors in the coolant. If the dye changes color then the exhaust vapors are leaking into the coolant and your headgasket is blown. Try both tests. Good luck.
Old Dec 7, 2004 | 08:25 PM
killer hatch's Avatar
you might have cracked the cylinder wall
Old Dec 7, 2004 | 08:32 PM
limpy's Avatar
Default Re: milky coolant (killer hatch)
awsome... thanks guys. we think the head might be a little warped too. were going to shave it and put a new head gasket and see how it goes. thanks again.
Old Dec 9, 2004 | 10:11 AM
Jago's Avatar
If the the colant and the oil in the crankcase is milky also the block is cracked.
just saw it at work yesterday.
H22AJSPEC
May 23, 2012 12:49 PM
Maple50175
Honda Civic (2001 - 2005)
Jun 9, 2009 05:28 PM
b00sted4dr
Oct 11, 2006 11:35 AM
MattyDA
Jan 29, 2006 01:15 PM
hybridb18
Aug 6, 2003 09:00 PM
