better gearing for highway?
transmission codes too short for search, so i need to post - which of these three transmissions are better geared for highway driving?
y21
s21
ys1
i do a lot of highway driving and don't want the car to be screeming high rpms driving to and from work every day and i am going to be looking at doing the b16 swap into my civic sometime, so i need to know which tranny to get when i get the swap. thanks.
y21
s21
ys1
Maybe a b16 tranny with an LS 5th gear
https://honda-tech.com/zerothread?id=555929
get an HF tranny
its great on the freeway LOL I had a ZC CRX with HF tranny for a month, it got 40 mpg and 1st gear was fun... after 20mph LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchblack »</TD></TR><TR><TD CLASS="quote">transmission codes too short for search, so i need to post - which of these three transmissions are better geared for highway driving?
y21
s21
ys1
i do a lot of highway driving and don't want the car to be screeming high rpms driving to and from work every day and i am going to be looking at doing the b16 swap into my civic sometime, so i need to know which tranny to get when i get the swap. thanks.</TD></TR></TABLE>
Do you need a hydraulic or cable tranny? What year Civic are you swapping into?
y21
s21
ys1
ok, some useful info here, and some not so useful info. First, the b16 with ls 5th gear sounds really good, however it even says there are no more parts available as they have been discontinued and no longer available in the states. hmmm. that doesn't really help if i can't get the parts, but i can look into seeing if i can get them. as for the guy who said get an hf tranny, that won't work. i have an hf tranny in my car now and get the exact same gas mileage as i did with my si tranny and they shift at exactly the same rpms as before. but i have a 89 civic and want to go from the z6 motor that i put into it to the b16, which is a b series, so the hf or si tranny isn't going to help. also i can do the hydro to cable conversion so whichever tranny is better geared for highway driving is what i want. so, as i originally posted, which of the three transmissions would be best for highway driving? or perhaps i could just use the ls transmission or another transmission that would be better? i don't need to have super short gears, since i don't drag race the car. i autocross it, so a little bit longer in 2nd wouldn't be a bad thing anyway. for now i can try to find out about getting that ls 5th gear and counter gear, but how about a whole transmission that would bolt up that i can get parts for that aren't discontinued? thanks.
i'll tell you right now.....The ys1 is not your best bet for Freeway speeds. Yeah from 0-60 in less then 5 (in an hf) but on the freeway you have to drop into 4th at 6k to get it to drop down and go...and then not but 2 secs later shift into 5th where you hit top speed real quick......You can have the best of both world's drag like tranny/motor combo...but you can't get the parts for the Drag and/gas mileage/top end....Good luck.....
ys1 w/ lsd is so badass though
There are two YS1 transmissions.
One was in the GSR the other was in the LS.
The cable LS is geared tallest of the B cable transmissions.
You could also build a hydro LS trans in a cable case (92-93).
That would give moster highway gears but poor accelleration.
I got an LS in my **** and it's got A1 I believe written on it and my spare tranny is also an LS YS1 and like JohnnieChimpo said there are two different ones but I got the LS one thank goodness.
null.
Jan 14, 2005 10:45 PM
eg360B
65
Sep 29, 2004 12:49 PM
