b20 crank or gsr crank on my b20vtec???
Old Dec 7, 2004 | 05:58 PM
hybridpatient95's Avatar
Default b20 crank or gsr crank on my b20vtec???
i was advised to use a gsr crank by a shop here. they say that the b20 crank cant take the punishment which i know but only until like 8500 or more. what would happen if i used a gsr crank would i be destroked?? i was just wondering the benefits of this. thanks
Old Dec 7, 2004 | 06:08 PM
HONDABROMANDUDE's Avatar
Default Re: b20 crank or gsr crank on my b20vtec??? (kinkbmx159)
Yes, a b18c crank will slightly destroke it but the b20/b18a crank will work just fine. The dude at the shop is full of it.
Old Dec 7, 2004 | 06:09 PM
hOndafienD 04's Avatar
ha i knew it! thanx for the fast reply man!
Old Dec 7, 2004 | 08:26 PM
Hella_Fresh's Avatar
Default Re: (hOndafienD 04)
i would go with a LS crank.. those things are very good, if they can withstand some high psi, i know they will be good for your b20/VTEC.
Old Dec 7, 2004 | 09:09 PM
RenoRacing's Avatar
Default Re: (sXekid)
b20 and ls cranks are the same!
Old Dec 7, 2004 | 09:10 PM
Default Re: (RenoRacing)
opps hahaha
Old Dec 8, 2004 | 12:08 PM
iiight gangsters thanks!!
Old Dec 8, 2004 | 03:19 PM
swaytec360's Avatar
Default Re: (kinkbmx159)
gsr crank has a better rod stroke ratio then ls but u will have to use gsr rods also yes this will destroke it but it all depends on where u want ur power and what kinda cams ur going with i took my b20vtec to 8500 a lot and my lsvtec to 9k with ls cranks so they can take it but id def use arp rod bolts and get it balanced
Old Dec 8, 2004 | 04:18 PM
Default Re: (swaytec360)
yea true yoo those were on the list
Old Dec 8, 2004 | 04:34 PM
this is gonna be running on buddy club stage 3's so the higher revs would be benificial..
Old Dec 9, 2004 | 02:06 AM
Twiet's Avatar
Why not get some other cams then?
I think their are better ways you could spend the $ you will need for the crank, whilst losing displacement!
Old Dec 10, 2004 | 04:04 PM
what cams would you suggest?
Old Dec 31, 2004 | 07:45 PM
GWInquisitor14's Avatar
Correct me if im wrong, but isn't it with the B20 or LS crank, you are gonna have more displacement so more torque but you wont be able to rev as high as B18C crank. That one will give you more revs but with a little less torque.
Old Dec 31, 2004 | 11:14 PM
H25's Avatar
H25
Default Re: b20 crank or gsr crank on my b20vtec??? (frankenfiend 04)
b20 crank
Old Jan 3, 2005 | 10:07 PM
Circuit Star-29's Avatar
Default Re: b20 crank or gsr crank on my b20vtec??? (MHRacing-310)
^^^^^ You just heard the word!!!!
Old Jan 3, 2005 | 10:11 PM
rodimus's Avatar
Default Re: b20 crank or gsr crank on my b20vtec??? (nathan atwell)
https://honda-tech.com/zerothread?id=595138
Old Jan 4, 2005 | 04:26 AM
jdmsi1320's Avatar
The b20/ls crank have a different stroke than a gsr crank. you will be safe with the b20/ls crank at high revs
Old Jan 4, 2005 | 06:37 AM
Default Re: (jdmsi1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsi1320 &raquo;</TD></TR><TR><TD CLASS="quote">The b20/ls crank have a different stroke than a gsr crank. you will be safe with the b20/ls crank at high revs </TD></TR></TABLE>
Captian Obvious has graced this thread. Thank you.
Old Jan 4, 2005 | 12:38 PM
Plugs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">b20 crank</TD></TR></TABLE>
Old Jan 4, 2005 | 01:06 PM
:__H__:'s Avatar
Default Re: b20 crank or gsr crank on my b20vtec??? (ickabod)
i've seen them spun to 9500 on daily drivers, accidently more than that in misshifts. dont think theres any problems... yet
Old Jan 4, 2005 | 05:07 PM
9500? god damn thats fast....my h23 would never last at even 7000.....:thumdown:
amios
Aug 14, 2009 11:41 AM
AK94GSR
Sep 28, 2007 12:22 AM
hoskos
Jan 29, 2006 09:39 PM
jdm92teg
Apr 13, 2005 01:20 PM
5w20
Dec 4, 2004 11:57 PM
