what makes more power lsvtec turbo or gsr turbo????????
Old Dec 7, 2004 | 05:46 PM
wilntegra's Avatar
Default what makes more power lsvtec turbo or gsr turbo????????
lsvtec (gsr/ls) with engine upgrades or stock gsr (96-98) with engine upgrades please let me know i gotta pick one???
Old Dec 7, 2004 | 05:54 PM
SiR Inspired ED7's Avatar
Default Re: what makes more power lsvtec turbo or gsr turbo???????? (wilntegra)
just make sure you get some good tuning
Old Dec 7, 2004 | 05:57 PM
Khelm's Avatar
Umm... such a vaug question depends on what you put in the block what turbo you run.... There are just so many diffrent ways of doing it.
Im going to say ls/vtec. But unless you have money to do it again and again over and over then dont do it. Mix and Match engines are weak.
Just let me put it this way I'v see a ls/vtech make 319 at the wheels.
Old Dec 7, 2004 | 06:03 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: what makes more power lsvtec turbo or gsr turbo???????? (Khelm)
id say lsvtec-T cuz the Tq yeaaaaa baby....but who cares cuz if a car makes 300 whp who cares if its gsr-t or lsvtec-t
Old Dec 7, 2004 | 06:07 PM
Khelm's Avatar
Default Re: what makes more power lsvtec turbo or gsr turbo???????? (TeGmAn18)
wow your so ignorant to the concept of an engine.
Old Dec 7, 2004 | 06:10 PM
and lsvtec is not weak if built right..tell him both sides if ur gonna say anything
Old Dec 7, 2004 | 06:18 PM
campbuds's Avatar
TOO MANY VARIABLES!
You can build either to be awesome.
Old Dec 12, 2004 | 07:48 AM
boost fed ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khelm &raquo;</TD></TR><TR><TD CLASS="quote">Umm... such a vaug question depends on what you put in the block what turbo you run.... There are just so many diffrent ways of doing it.
Just let me put it this way I'v see a ls/vtech make 319 at the wheels. </TD></TR></TABLE>
and you have the right to say he is ignorant, where do you get your facts at. Please show me proof of your findings. You are right about the qurstion being "vaug" and how it depends on what your set up is but to make a comment like this " But unless you have money to do it again and again over and over then dont do it. Mix and Match engines are weak." I have not seen proof of this. Its only weak if you assemble it wrong or do a half as* build.
A ls/vtec motor is not much different than a gsr motor when built. Its only cheaper if have a b18a/b block laying around. People who are going the route of ls/vtec are making the same if not more power than a b18c motor.
Old Dec 12, 2004 | 08:19 AM
shermanyang's Avatar
Default Re: what makes more power lsvtec turbo or gsr turbo???????? (boost fed ls)
as most have stated, either motor will allow you to reach your power goals. only the LS/Vtec motor will yield better torque as a result of the displacement. the only problem with the LS/Vtec motor is that it does tend to break down if assembled poorly. so the decision is really up to you...don't let others make decisions for you. just find out the cold hard facts on each build, know what you want, and just build your dream car/motor.
Old Dec 12, 2004 | 01:05 PM
ProjectDarkBlack's Avatar
port out the ls head turbos enable you to make as much power as humanly possible if it big enough. v-tec or no-tec
Old Dec 12, 2004 | 01:16 PM
Rory Breaker's Avatar
Default Re: (ProjectDarkBlack)
Thats good advice. Ive seen ported LS turbo setups make awesome numbers compared to stock head LS setups.
Also, KHelm, you seem like the ignorant one. What does your comment of "um lets just say Ive seen 319whp LS/VTEC" mean? Do you want a pat on the back? Ive seen 700whp GSR setups and 500whp LS/VTEC setups, does that mean one is better than the other? You need to learn how to make sense on here before you start making suggestions and offering advice.
As someone else mentioned, all things considered equal, the LS/VTEC tit for tat will typically result in more torque. Enough that I would go out of my way to swap the shortblock? No.
JWHATCH23
Sep 6, 2006 11:41 PM
integralsdriver29
Jan 19, 2005 06:38 PM
.doeboyfresh.
Sep 15, 2004 02:37 AM
ViLLaiNx89
Aug 15, 2004 07:25 AM
hondanacura4life
May 15, 2002 11:31 AM
