GSR Swap finish. NOw smogging
Old Dec 7, 2004 | 04:33 PM
SexyAzNMami's Avatar
Default GSR Swap finish. NOw smogging
I got two bottles of sea foam, Put one WHOLE BOTTLE in the gasoline. Put 1/2 into the brake booster hose, and 1/2 into the crank case. Turn the car on and it smoke out like crazy. I love this ****. ;] anyways. I'm in the process of smogging the jdm gsr. Do i just leave the sea foam inside the engine and gasoline?
Or do i have to get oil change? filter oil change? and use up all the gasoline and refill it again? What must i do?
Old Dec 7, 2004 | 04:36 PM
drdisco69's Avatar
Default Re: GSR Swap finish. NOw smogging (SexyAzNMami)
Change the oil as soon as possible, and I'd run fresh gas.
Old Dec 7, 2004 | 04:45 PM
Reelizmpro's Avatar
Default Re: GSR Swap finish. NOw smogging (drdisco69)
Change the oil within 500 miles or 300 to be safe and run it with it in the gas tank...it's not going to hurt anything. 1/2 a can is about 6 oz...that's not enough solution to thin out an oil THAT much. Oils tend to thin out with regular usage anyway so this will just accelerate that.
Old Dec 7, 2004 | 06:44 PM
Default Re: GSR Swap finish. NOw smogging (Reelizmpro)
Alright thank you so much for your advices. If i do pass smog ( NoX ) on this gsr motor. I will be so happy and it will be my first smogging that i did.
I'll keep you posted on the smogging once I get to it tomorrow morning.
' Learning all i could about boosting gsr ' - New year resolution.
DEEABLO
Jul 31, 2009 02:10 PM
mnbvcxz358
Apr 12, 2008 07:32 AM
TTE TEG
Oct 21, 2005 05:54 AM
JamaicanDM
Jan 13, 2005 05:33 PM
jaredfmn
Jun 19, 2002 08:45 PM
