d15a3 to d16a1 need help,
Old Dec 7, 2004 | 03:20 PM
parts890's Avatar
Default d15a3 to d16a1 need help,
89 d16a1, i have complete wiring from 5 speed and auto both do same, motor starts and runs for 1 to 2 seconds and dies, starts immediatly everytime but dies everytime. it is in a 1986 crx si , the tranny is 5 speed, replaced map sensor, tps, i wired the fuel pump to run constantly, i havent replaced the distributor or the exhaust cam sensor. only shows one code, code 19, for a missing automatic transmission sensor, will the motor still run with this code. Will it run with the automatic ecu and firewall wiring harness? Is it possible to put an 86-87 vacuum advandce distributor onto the 89 motor and use my 86 si ecu and wiring?
Old Dec 7, 2004 | 04:46 PM
dr_latino999's Avatar
Default Re: d15a3 to d16a1 need help, (parts890)
Wrong link, http://www.redpepperracing.com...ticle
Modified by dr_latino999 at 9:36 PM 12/7/2004
Old Dec 7, 2004 | 05:04 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
All 1g CRX/3g Civic all the time. Read the FAQ *FIRST*.
BigbamaBen
Mar 17, 2013 12:09 AM
Bozo_JDM
Apr 29, 2009 10:57 AM
DancingDorito
Sep 27, 2004 08:40 AM
Acid832
Aug 9, 2003 12:25 PM
Civic Racer X 7
Aug 4, 2003 10:50 AM
