KS, TPS, Idle
Old Dec 7, 2004 | 03:18 PM
ferio 95's Avatar
Default KS, TPS, Idle
Ok my idle is surging from 1k-3.5k. As of now the only codes im having are 7 and 23 which are TPS and Knock sensor. my question is can either cause my idle to surge like that?
Old Dec 8, 2004 | 06:01 PM
ferio 95's Avatar
Default Re: KS, TPS, Idle (ferio 95)
Old Dec 9, 2004 | 04:28 AM
JimBlake's Avatar
I'd say your TPS can do that. Or vacuum leaks. Or dirty IACV or FITV...
Old Dec 9, 2004 | 06:24 AM
Dan GSR's Avatar
Default Re: KS, TPS, Idle (JimBlake)
check your tps
closed should be .5v, WOT should be 4.5v
last time i had and idle surge, i found a crack in my intake manifold
Old Dec 9, 2004 | 09:09 AM
ferio 95's Avatar
Default Re: KS, TPS, Idle (Dan GSR)
well for some reason my 5v wire is reading like battery voltage of like 11-13v
EJuno
Feb 5, 2008 06:20 PM
1990si
Dec 11, 2006 10:01 AM
b16a1civichb
Jun 4, 2003 04:24 PM
