92-93 GSR suspension into 90crxsi
Old Dec 7, 2004 | 02:48 PM
ImportRicer's Avatar
Default 92-93 GSR suspension into 90crxsi
any idea how to do this?
will it fit directly?
Old Jan 25, 2005 | 05:42 PM
pwrofdrm's Avatar
Default Re: 92-93 GSR suspension into 90crxsi (ImportRicer)
Hey...I have this same question, only I have a 90 Dx.
I'm going to be swapping in the suspension from a 92 GS-R, and I want to upgrade my shocks/springs to a set of Omnipower Streets...which application should I order them for, CRX or Integra? Should I also swap LCA's? What about sway bars? I have the whole car at my disposal, so everything I can use I am going to. Thanks
Old Jan 26, 2005 | 07:36 AM
pwrofdrm's Avatar
you can't tell me that no one knows anything about this...
Old Jan 26, 2005 | 08:06 AM
.Noah Fecks's Avatar
Default Re: 92-93 GSR suspension into 90crxsi (lax1185)
look under the FAQ thread at the top of all the threads. it tells how to do a 5 lug. so do the same thing, but with gsr parts instead
Old Jan 26, 2005 | 09:47 AM
hahagasdcrx's Avatar
Default Re: 92-93 GSR suspension into 90crxsi (Noah *****)
It should all bolt up the same as doing the LS suspension. You should still use the shocks and springs for a CRX.
All you should need from the DA is the front knuckles, caliper, and rotors ( maybe brake lines if you want but not necessary). Take the whole rear suspension ( whole trailing arm w/ caliper and rotor). Also take the master cylinder and proportioning valve.
Your CRX should already have rear disk, so take the Tegs and sell them. You can use the front knuckles to have bigger brakes( bolts right up) but need to get an alignment afterwards. Replace the MC with the integra one so your brake pedal isnt so mushy.
Old Jan 26, 2005 | 11:42 AM
EL Vap133's Avatar
Complete suspension? Or just shocks/struts? Or just front and rear brakes?
Old Jan 30, 2005 | 08:55 PM
pwrofdrm's Avatar
Default Re: 92-93 GSR suspension into 90crxsi (EL Vap133)
just front and rear brakes...should I order the CRX or Integra coilovers?
Old Jan 30, 2005 | 09:52 PM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
hey, I have an 1988 dx HB with 93 gsr Brake all the way around. as for the struts, I use 92-95 Civic up front( changed out the fork) and 89-91 civic rears. the coilovers I use are for my car, if you use the ones for a integra the spring rate will be too high. As for the Master cylinder and brake booster, I was using the integra, but I just swapped them for a set off of an 91 prelude Si and they work great. In case you where wondering I am using the PV off of a 91 CRX Si, so far things are great.
tigerr227
Feb 12, 2008 09:05 PM
SVOboy
Aug 22, 2005 04:38 PM
eREXion91
Suspension & Brakes
Mar 8, 2005 09:56 AM
PartTimeRiceR
Jan 27, 2003 06:52 PM
Brian_92GSR
Nov 12, 2002 12:45 PM
