obd conversion help...
Old Dec 7, 2004 | 02:34 PM
Dee A Nine's Avatar
Default obd conversion help...
damn man. i'm been trying to find help and i'm not getting ****. i'm trying to convert my DA's obd0 setup to the OBD1... what harnesses would i need? one guy from a junkyard told me i could just change the injectors plugs and that's it... what do i really really need in order for this conversion **** to happen!? PLZZ!!! my car's throwing up codes... it's already throwing the atmo pressure sensor (code 13)!~
Old Dec 7, 2004 | 03:07 PM
Kataku2K3's Avatar
Default Re: obd conversion help... (Dee A Nine)
You can't just change injector plugs because that's not even the issue. If you changed the plugs to run high impedance injectors then you'd need to rewire out the resistor box which isn't a big deal, it's just totally unnessecary. The main thing you do need to change is the distributor to an OBDI or OBDII one (they're both internally the same, just use whatever connector you need). Besides that you'll need to make or buy a nonOBD-OBDI jumper.
Old Dec 7, 2004 | 03:42 PM
hondaguyef's Avatar
Default Re: obd conversion help... (Kataku2K3)
Contact Blown90hatch. He makes excellent conversion harnesses and gives excellent tech support. He will also beat any advertised price. https://honda-tech.com/zerothread?id=997093
Phil
Old Dec 7, 2004 | 03:44 PM
eda6's Avatar
You need 4 wire o2 sensor, obd 0 to obd 1 conversion harness , obd 1 or obd 2 dizzy, obd 1 ecu.
Old Dec 7, 2004 | 04:16 PM
Kataku2K3's Avatar
Default Re: obd conversion help... (eda6)
****, I knew I was missing something but I couldn't remember what... Yea eda6 heated oxygen sensor circuit.
Old Dec 7, 2004 | 04:30 PM
Dee A Nine's Avatar
alright ht. thanks for the help.it's just that when i get it done. i don't wanna get ripp'd off for the people who are gonna do the work to use long terminology to try to get more money out of me.. thanks. but can i avoid takin it to the shop by doing it myself? what's the difficulty scale 1-10 for something like this to do on my own?
Old Dec 7, 2004 | 04:37 PM
Kataku2K3's Avatar
If you're fairly comfortable with wiring and you understand most of the basics on a Honda you shouldn't have a problem at all. I converted my friend's Rex ~3 years ago to OBDI and at that time no one was even really making jumpers. Just take your time on setting up the harness and you shouldn't have any problems. Again I've posted this a ton of times but here's what my jumpers and reworked nonOBD harnesses look like. I'm extremely **** about this kind of **** tho...
Will's (WillieWillieFast) Rex harness torn apart with a few new extra connectors and VTEC stuff...
Completed nonOBD-OBDI jumper
All Done
Old Dec 7, 2004 | 04:43 PM
hondaguyef's Avatar
Kataku2k3 gets for that harness. That's excellent work. It looks much better than my rat's nest . Is that a 2/3 bar pigtail and connector I see as well?
Phil
Old Dec 7, 2004 | 04:46 PM
eda6's Avatar
I used wire nuts at first to check my work. After I was code free I soldered everything and used heat shrink tubing.
Heat gun+soldering iron+1/4" heat shrink tubing=very clean install
If you get a harness from blown90hatch the difficulty would be 2.
Old Dec 7, 2004 | 05:41 PM
Kataku2K3's Avatar
Thanks, yea that's a GM MAP connector. Will used this harness for one season with his B16 turbo motor and Hondata. With his new motor we're running Motec so we'll see how clean I can make that harness...
Old Dec 7, 2004 | 08:25 PM
PrettyLude's Avatar
that harness looks better than factory
Old Dec 7, 2004 | 08:36 PM
Dee A Nine's Avatar
daayam... that **** looks hella complicated tho... say if i did have the harnesses.... where do i start?
97BB6Type-SH
Jun 1, 2008 02:42 PM
turboteg86
Mar 5, 2007 04:51 PM
91lsteg
Jan 9, 2005 11:43 AM
Kwuaymaikrup
Sep 27, 2003 09:23 AM
AB16A2T
Jul 13, 2002 09:02 PM
