Need some input on this about cable B16 tranny!!!
Old Dec 7, 2004 | 02:27 PM
Skank_aSS_Dara's Avatar
Default Need some input on this about cable B16 tranny!!!
my brother has a cracked outter tranny case and was wonder if a ys1 outter tranny case would fit on it to replace it my brother's tranny is a Y1 would the ys1 fit perfectly like a snap or no
thanks in advance
-dara
Old Dec 7, 2004 | 06:29 PM
Default Re: Need some input on this about cable B16 tranny!!! (DaRa_Da_SkAnK)
Y0!!!
Old Dec 7, 2004 | 07:48 PM
SiR Inspired ED7's Avatar
Bump,
Reprasenting the So Cal
Old Dec 7, 2004 | 09:02 PM
Colin's Avatar
no, it will not fit. 89-91 and 92-93 b series cable trannies are quite different, and most all of the parts do not swap over between the two generations.
Old Dec 7, 2004 | 11:29 PM
Default Re: Need some input on this about cable B16 tranny!!! (91IntegGS)
anymore inputs?
Old Dec 8, 2004 | 12:05 AM
Colin's Avatar
you may not get the input you want here.... there typically has been very little support for the DA on these forums.
My first response is to say "why the **** don't you believe me, I know what I'm talking about!!!" However, I realize that you don't know me, and if I were you I would also be skeptical (which is smart, because there is a lot of bad/faulty info going around on the forums these days).
I suggest you go to http://www.g2ic.com and do some searches. It should become evident pretty quick that you cannot swap cases. the design of the Internals is quite different (in particular how the shift forks are designed and held in place by the casing). Also, gearspeed may be able to help you find a "for sure" answer.
Good Luck
Old Dec 8, 2004 | 12:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS &raquo;</TD></TR><TR><TD CLASS="quote">you may not get the input you want here.... there typically has been very little support for the DA on these forums.
Good Luck </TD></TR></TABLE>
i did not say i dont believe you i just wanted another person to maybe back your post up or if they have any other words on their side, but in that case if your the only one that replied yes i do and been believing your words because what you said made sence about the difference of the years in the trannies
Old Dec 8, 2004 | 03:34 AM
acurar0ss's Avatar
I got a y1 case if you are looking for one.
Old Dec 8, 2004 | 04:36 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaRa_Da_SkAnK &raquo;</TD></TR><TR><TD CLASS="quote">
i did not say i dont believe you i just wanted another person to maybe back your post up or if they have any other words on their side, but in that case if your the only one that replied yes i do and been believing your words because what you said made sence about the difference of the years in the trannies </TD></TR></TABLE>
Ok, I'll back him up. It won't fit.
Old Dec 8, 2004 | 10:02 AM
Colin's Avatar
Its definitely a good thing to try and get second opinions.... not putting you down, just commenting.
Old Dec 8, 2004 | 03:26 PM
Default Re: Need some input on this about cable B16 tranny!!! (acurar0ss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurar0ss &raquo;</TD></TR><TR><TD CLASS="quote">I got a y1 case if you are looking for one.</TD></TR></TABLE>
how much?
dc4ok
May 25, 2011 07:36 PM
shawn_crx
Mar 2, 2006 07:44 PM
Orangedragone
Jul 29, 2005 01:09 PM
arielmalespin
Feb 15, 2005 08:41 PM
