Bushings
Old Dec 7, 2004 | 01:39 PM
TeaAddict's Avatar
Default Bushings
bushings...
what are they?
what do they do?
i hear mine are worn, do i have to replace them?
what are some good aftermarket companies that make bushings?
thanks
Old Dec 7, 2004 | 02:55 PM
TeaAddict's Avatar
Default Re: Bushings (TeaAddict)
up
Old Dec 7, 2004 | 04:36 PM
TeaAddict's Avatar
up up
Old Dec 7, 2004 | 04:45 PM
Racermech's Avatar
Bushing are all over your car. suspension, sway bars......etc
If they are worn then you should replace them
Check out http://www.energysuspension.com/ these are a good upgrade
Old Dec 7, 2004 | 04:58 PM
b18c1bomex's Avatar
It's usually good to replace anything that is wore
Old Dec 7, 2004 | 05:20 PM
SiR Inspired ED7's Avatar
just go to Kragen
Old Dec 7, 2004 | 07:21 PM
mdpalmer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict &raquo;</TD></TR><TR><TD CLASS="quote">bushings...
what are they?
Some bushings are disk-like pieces of rubber (or some sort of plastic type material), with a doughnut-like hole in the middle of it; others are sphere-like with a hole.
what do they do?
Bushings are typically used to provide some flexibility between an inner shaft and an outer shaft or between a shaft and a fixture. In a typical application, there is relative twisting between the inner shaft and outer shaft/fixture. A good example of this would be the connection between rear lower control arms and chassis. A bushing sits between a bolt and the LCA. As someone mentioned already, there are quite a few places in the suspension that have bushings. There are also a few bushings on your shift linkage.... and your stabilizer (a.k.a. sway) bars.
1. You don't have to replace them. However, your ride quality, overall handling, and component longevity may be comprimised very slightly if you don't have bushings which are in reasonable condition.
2. I don't know. You may want to talk to people in the tech or road racing boards about this. If in doubt, use OEM parts.
Good luck. P.S. There is a LOT of information on bushings in the archive.
young noob #2
Suspension & Brakes
Jul 7, 2008 06:43 AM
mrvrsick
Jun 29, 2008 02:03 PM
92egSnatch
Honda Civic (2001 - 2005)
Apr 14, 2008 09:18 AM
wicked2night
Dec 31, 2006 07:34 AM
MugenHonda
Apr 28, 2004 11:29 AM
