HX GUY NEED HELP W/ B2O
Old Jan 2, 2002 | 05:54 AM
dohcsideSi's Avatar
Default HX GUY NEED HELP W/ B2O
i forgot which gsr parts i needed to swap over the girdle, i know i need the pickup, main bolts, and the baffle what else do i need? btw which oil pan do i use? and can i use a b16 pan? thanks b20 coming to a flatback near you!
Old Jan 2, 2002 | 10:12 AM
VaporTrail's Avatar
New User
Default Re: HX GUY NEED HELP W/ B2O (dohcsideSi)
you also need the GSR windage tray, and GSR/Type R oilpan (Moroso can also be used if you use their pick up). Somebody correct me, but don't you also want to use a GSR/Type R dipstick due to the deeper pan?
Old Jan 2, 2002 | 04:45 PM
boosted3g's Avatar
Default Re: HX GUY NEED HELP W/ B2O (VaporTrail)
Moroso lists the same parts #s for the vtec and the Ls oil pan so im assuming that the pan depth is the same. However the pick up is different.
Old Jan 2, 2002 | 11:35 PM
VaporTrail's Avatar
New User
Default Re: HX GUY NEED HELP W/ B2O (boosted3g)
actually, you are right. You can use the same Moroso pan, but you could not use a OEM LS pan. The depth is too shallow to clear the GSR windage tray.
Old Jan 3, 2002 | 06:08 AM
HX_Guy's Avatar
First off, the GSR/ITR oil pan is not deeper then the LS/B16...it has a slightly different design (baffling) which is why you cant use the LS pan.
So yea, you need the girdle, oil baffle, GSR oil pickup, GSR oil pan and GSR main bolts (3 middle caps)
Old Jan 3, 2002 | 06:52 AM
rainforest's Avatar
Default Re: HX GUY NEED HELP W/ B2O (HX_Guy)
so basiclly he needs everything below the main caps.
Old Jan 3, 2002 | 10:55 AM
dohcsideSi's Avatar
JUST WANTED TO SAY THANKS GUYS!!!
KashAddikt
Mar 24, 2014 07:29 PM
Daniel-sanB1
Jun 25, 2007 03:18 PM
Death_to_Thieves
Nov 4, 2006 05:53 AM
built562
May 11, 2003 06:39 PM
DD_JonnyLee
Jan 17, 2003 02:54 AM
