H22 swap for a 91
Old Dec 7, 2004 | 09:39 AM
91H22Accord's Avatar
Default H22 swap for a 91
Does any one know anything about this swap like can i use the motor mounts from my f22. is it an easy swap or do i have to move a lot of stuff around etc...
Old Dec 7, 2004 | 09:41 AM
Q.S.'s Avatar
bump
Old Dec 7, 2004 | 09:53 AM
Default Re: (Q.S.)
what do you mean?
Old Dec 7, 2004 | 10:07 AM
Luisito825's Avatar
Default Re: (91H22Accord)
http://board.hondasociety.com/...61998
Old Dec 7, 2004 | 10:18 AM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91H22Accord &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean?</TD></TR></TABLE>
bump means bumping it back up to the top so people will see it, as for the swap, stock axles/int shaft/mounts/linkage will work, u will have to mod the exhaust and wire harness and ps lines and fuel lines, for more details search
Old Dec 8, 2004 | 09:46 AM
Default Re: (twistedbydezign)
well if i am getting the wiring harness for the h22 i wouldnt have to worry about modifying it would i?
Old Dec 8, 2004 | 09:56 AM
http://www.osakajdmmotors.com/introhonda.htm
check this place out......you get the engine, tranny, wiring harness, ecu....pretty much everything you can buy the shiftlinkage and axles
Old Dec 8, 2004 | 10:08 AM
smooth95's Avatar
Its pretty simple same motor mounts
Old Dec 8, 2004 | 11:25 AM
.dave's Avatar
i HAS questions ?
Default Re: (smooth95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooth95 &raquo;</TD></TR><TR><TD CLASS="quote">Its pretty simple same motor mounts</TD></TR></TABLE>
The F and H series engines and transmissions are interchangable as well, aren't they?
Old Dec 8, 2004 | 09:45 PM
roll5104life's Avatar
same motor mounts wireing harnes has to be moddes a lil check out http://www.cb7tuner.com
markass420
Jun 30, 2011 01:32 PM
cmracing
Jul 19, 2008 03:41 PM
slo_hatch
Mar 31, 2008 04:27 PM
ennah
Apr 16, 2006 07:30 AM
quaker
Jan 12, 2004 01:31 PM
