my sohc setup : review before i put it back together >>
Old Dec 7, 2004 | 06:55 AM
platinum00's Avatar
Default my sohc setup : review before i put it back together >>
ok, please take a look at my setup. Im shooting for ~400whp. is this enough and safe.
sohc d16y8
benson sleeved stock bore
cp 9.1 pistons
eagle rods w/ arp2000 bolts
mircopollished crank
OEM headgasket
ARP Headstuds
d16y8 head
port pollished
3 angle valve job
new OEM springs, retainers, valves
stock cam ( selling )
Zex 105300 ( Ordered )
suptertech springs and TI retainers ( Ordered )
pcv system removed. running catch can.
stock d16y8
OBX LSD
ACT Clutch and pressure plate ( selling )
Action 2MS - ( Ordered )
8.5 lb aluminum flywheel
stock axels
t3/4 .48 a/r 50 trim ( Selling )
sc50 ( ordered )
custom Equal length manifold
tail 38mm wastegate w/ 10 psi spring
hks SSQ bov
JRC 8" intercooler
custom 2.5 charge piping
custom 3 inch downpipe
custom 3 inch turbo back exhaust , manaflow muffler
p28 hondata s200 w/boost
greddy profec b spec II
RC 750cc injectors
walbro 255 fuel pump
MSD Cap , and external coil
Autometer water, oil, boost, a/f, egt gauges
I think that's it, im sure i forgot something. im wondering if i should upgrade my valve sprins and retainers. can i achieve my goal with the stock ~7k rev limit or will i need to rev it out a bit more.
anything else im missing before i put this beast back together.
thanks for everyones help on my new setup
platinum.
Modified by platinum00 at 3:15 PM 12/8/2004
Modified by platinum00 at 7:52 PM 12/17/2004
Old Dec 7, 2004 | 07:17 AM
ELSpool's Avatar
kickass set up, I think you will get there around 25psi.
Old Dec 7, 2004 | 07:21 AM
Adi Radoncic's Avatar
On Fire!
Default Re: my sohc setup : review before i put it back together >> (platinum00)
I would add a cam, get a bigger turbo, and get some valve springs and retainers just because its better to be safe than sorry. What size rod bolts, 3/8" or 7/16"??
Other than that
Old Dec 7, 2004 | 07:28 AM
platinum00's Avatar
Default Re: my sohc setup : review before i put it back together >> (newgsr)
i went with this turbo size for a decently quick spool. will it not support 400 ponies.
how do i tell what size rod bolts i have.
platinum.
Old Dec 7, 2004 | 07:51 AM
h3avyarms's Avatar
The turbo is not good for 400whp. I have a T3 50 Trim w/ .48 a/r as well and its only good for about 260whp or so. It does spool nice though. I enjoy having 210wtq at 4k rpm.
Old Dec 7, 2004 | 07:54 AM
platinum00's Avatar
Default Re: my sohc setup : review before i put it back together >> (h3avyarms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h3avyarms &raquo;</TD></TR><TR><TD CLASS="quote">The turbo is not good for 400whp. I have a T3 50 Trim w/ .48 a/r as well and its only good for about 260whp or so. It does spool nice though. I enjoy having 210wtq at 4k rpm.</TD></TR></TABLE>
i dont agree.
i made 237 at 9psi.. with this turbo and a log style manifold
platinum.
Old Dec 7, 2004 | 07:59 AM
ELSpool's Avatar
He has a 50 trim T3, you have a 50 trim t3/t4...the turbo is rated for your goals. You will just need some boost to hit it.
Old Dec 7, 2004 | 08:18 AM
VTECisSeXY's Avatar
*insert here*
Default Re: (ELSpool)
sounds nice man
ill hafta come down to c-bus again to see this
Old Dec 7, 2004 | 08:40 AM
RyanEJ8's Avatar
That is a T3 50 trim. This is a T3/T4 50 trim. It CAN suport 400whp, but it will be pushing the limits of the turbo. I'd say between 27-30psi to get to that level.
Old Dec 7, 2004 | 08:42 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">He has a 50 trim T3, you have a 50 trim t3/t4...the turbo is rated for your goals. You will just need some boost to hit it.</TD></TR></TABLE>
That's what I was going to say... I would think it's possible to reach your goals with this turbo but you are really going to have to wind that sucker up!
Nice set up by the way
Old Dec 7, 2004 | 09:03 AM
platinum00's Avatar
Default Re: (EJ1 wilcox)
so should i worry about the stock rev. or will i be fine as long as a feed it some boost
i would be happy with 350whp too. 400 is a little much for the street anyway.
platinum.
Old Dec 7, 2004 | 09:21 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (platinum00)
sounds awesome!
I plan on doing the same thing, except stock sleeves.
Old Dec 7, 2004 | 01:09 PM
cody@cgracing's Avatar
Default Re: (boostincoupe)
i am making 420 whp and you have way more stuff then me. i think if you get a bigger turbo you can make the power you want....
Old Dec 7, 2004 | 01:19 PM
rextec's Avatar
did you get the bottom end balanced? just wondering
Old Dec 7, 2004 | 01:36 PM
platinum00's Avatar
Default Re: (11secsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> i am making 420 whp and you have way more stuff then me. i think if you get a bigger turbo you can make the power you want....</TD></TR></TABLE>
what size turbo are you running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> did you get the bottem end balanced? just wondering </TD></TR></TABLE>
it's not assembled yet, but it will be.
platinum.
Old Dec 7, 2004 | 01:44 PM
i am running an SC61 30psi.
Old Dec 7, 2004 | 02:20 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">I would add a cam and get some valve springs and retainers just because its better to be safe than sorry.
Other than that </TD></TR></TABLE>
Completely agree with the valvetrain and cam. Rev the **** out of it........safely.
What's a Ketch can?
Old Dec 7, 2004 | 02:56 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11secsohc &raquo;</TD></TR><TR><TD CLASS="quote">i am running an SC61 30psi.</TD></TR></TABLE>
30 psi on an SC61 only yielded 421whp for you? Something doesn't sound right.
Old Dec 7, 2004 | 07:20 PM
platinum00's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i am running an SC61 30psi.</TD></TR></TABLE>
jesus, maybe i do need to upgrade my turbo if that only did 421whp
platinum
Old Dec 7, 2004 | 07:27 PM
platinum00's Avatar
Default Re: my sohc setup : review before i put it back together >> (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Completely agree with the valvetrain and cam. Rev the **** out of it........safely. </TD></TR></TABLE>
how far can the stock cam take you if i just upgraded the springs and retainers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> what is a ketch can. </TD></TR></TABLE>
fixed, thanks. i guess i just type the 1st sh*t that pops in my head.
platinum.
Old Dec 7, 2004 | 08:13 PM
.::Lee::.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
30 psi on an SC61 only yielded 421whp for you? Something doesn't sound right.</TD></TR></TABLE>
Really? Sounds about right to me with stock head. I'm not being critical of your assesment, I'm just wondering what a setup like that should be making.
I'll be running a 57 trim t3/to4e and I would be more than happy if I was making 325 hp.
Old Dec 7, 2004 | 11:27 PM
omahaturbocivic's Avatar
Default Re: (Ibiza)
I would definatley get the springs and retainers, thats my next priority on my semi built d series because shifting at 7k with our longer trannys sucks when you have turbo lag. My t3/04b .63 ar does not hit full boost (15psi) till close to 5500 and with the d series tranny its drops to about 4500rpm when shifting and my boost falls to 10psi or less each shift and has to re-spool. If I could only shift a little higher it would make a significant differnece.
Also which act clutch do you have? A lot of the d series clutches dont seem to hang in there as well once you start making real power. My act hdss slipped bad once I turned the boost up and my new 6 pucks holds but I am still not too confident in it and I am worried it may be starting to slip too up top. I know someone else on here had a xtss slipping at only like 275hp too which is about where I beleive am as well.
Old Dec 8, 2004 | 03:54 AM
platinum00's Avatar
Default Re: (omahaturbocivic)
i believe i just have the hd plate and peformance disk.
can the stock cam goto 9k ?
platinum.
Old Dec 8, 2004 | 04:21 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">
platinum.</TD></TR></TABLE>
The stock Y8 cam dies off pretty early. Around 6500 (stops making power). I would recommend springs, retainers, zex 59300 cam.
Old Dec 8, 2004 | 04:29 AM
platinum00's Avatar
god damn it im broke
where is the best place to get the zex cam
platinum
