problem wiht my teg
Old Dec 7, 2004 | 05:27 AM
lilpdawg's Avatar
Default problem wiht my teg
Hey I was wondering if any of you guys know how to fix the speedomiter. I just changed my starter and it just stoped working and I need it fixed b4 i get my car inspected next week. Any idea's???????
Old Dec 7, 2004 | 06:34 AM
JimBlake's Avatar
Default Re: problem wiht my teg (lilpdawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilpdawg &raquo;</TD></TR><TR><TD CLASS="quote">... I just changed my starter and it just stoped working and I need it fixed b4 i get my car inspected next week. Any idea's???????</TD></TR></TABLE>Maybe you unplugged your VSS (or pulled it's wiring apart???
Old Dec 7, 2004 | 07:15 AM
sleevedgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you unplugged your VSS (or pulled it's wiring apart???</TD></TR></TABLE>
Yes he is right it is definitly your VSS! Take out your speedometer. Get your owner manual and find out which wire is VSS then check wire from top to bottom! If this does not work you may need VSS wire replacement because you may havea short in it.
Old Dec 7, 2004 | 09:19 AM
E Swift's Avatar
Did you check to see if you pulled your speedometer cable out of your tranny?
Old Dec 7, 2004 | 08:39 PM
slowww b18b1's Avatar
Default Re: problem wiht my teg (E Swift)
what year integra? DA's have some pully mechanism, DC's have the VSS on the tranny behind the distributor
Old Dec 7, 2004 | 09:59 PM
triple_s1x's Avatar
Default Re: problem wiht my teg (slowww b18b1)
Check your vss or cable, if its is the vss plug make sure to clean both conections before hand and use dielectical grease when you put it back together. THat connection also seems to get funky if its dirty.
Skyhigh07
Jun 12, 2008 06:53 AM
G0crxG0
100
Jul 21, 2006 06:13 AM
iNtoXicaTedSPOON
Feb 11, 2004 07:29 PM
THE94GSR
Jul 13, 2003 05:03 PM
Hatchy-Ownzjo0
Apr 24, 2003 06:48 PM
