Turbo Kits
Old Dec 7, 2004 | 03:01 AM
StRIB3_NZ's Avatar
Default Turbo Kits
Hey guys,
I have a 1990 Honda Civic h/b DOHC V-Tec siR (EF9), i was wondering if it is possible for you guys to tell me some websites where i could possible find out some info on turboing my car to make it even faster then it already is :-p ya know.
If you could please add a message cheers
WEST AUCKLAND!
NEW ZEALAND!
Old Dec 7, 2004 | 04:37 AM
messeduprex's Avatar
Default Re: Turbo Kits (StRIB3_NZ)
http://www.greddy.com
f-max
rev-hard
drag
turbonetics
Old Dec 7, 2004 | 05:21 AM
dr_latino999's Avatar
Default Re: Turbo Kits (messeduprex)
Hmm.......he would have to mix and match parts to get it to perfectly fit his chassis unless Greddy made a kit specific to the EF9.
Old Dec 7, 2004 | 05:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
https://honda-tech.com/zeroforum?id=16
and
https://honda-tech.com/zerosearch
Not trying to be a dick either. I have a turbocharged civic, and these two links gave me 95% of the info I needed to make it happen.
Old Dec 7, 2004 | 07:55 AM
slowpokesi's Avatar
Default Re: (DaX)
revhard b16a for crx kit its a bolt on kit, forget the ac, and you better have some money for a aftermarket traction bar kit, and a half size radiator, other than that, its pretty much bolt on!
Old Dec 22, 2004 | 07:29 AM
BlueShadow's Avatar
Default Re: (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">revhard b16a for crx kit its a bolt on kit, forget the ac, and you better have some money for a aftermarket traction bar kit, and a half size radiator, other than that, its pretty much bolt on!</TD></TR></TABLE>
Hey dood,
Didn't you used to have a Revhard kit for your B16 CRX that you eventually sold? or was it a different kit you had? what did you think about the RH build quality? I've only ever done research on Greddy, FMAX and DRAG, but never RH.
I'm thinking about ditching this whole NA deal and dropping a turbo in my B18C CRX. However as busy and impatient as I am now, I dont want to piece together another turbo kit. Maybe I'll order a DRAG or RH kit and just tell them to swap out the crappy parts.
Old Dec 22, 2004 | 07:43 AM
slowpokesi's Avatar
Default Re: (BlueShadow)
i was selling it but i ended up installing it on my car,
pics can be found here
https://honda-tech.com/zerothread?id=1089908
The only crappy parts that come with the kit is the fuel pump and fmu, other than the build quality is great, you will have to give up your ac, get a half radiator, and a aftermarket traction bar system, other than that its pretty much bolt on, no block shaving etc..
Old Dec 22, 2004 | 08:01 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">i was selling it but i ended up installing it on my car,
The only crappy parts that come with the kit is the fuel pump and fmu, other than the build quality is great, you will have to give up your ac, get a half radiator, and a aftermarket traction bar system, other than that its pretty much bolt on, no block shaving etc..</TD></TR></TABLE>
Sweet!!! so you ended up instaling anyways eh? you know when I saw your FS post on the kit, I thought about buying it. But at the time I didn't want another turbo car, and I didn't have enough money.
Thanks for the tip about the the kit. I'll probably give the FR crossmember and half rad setup a look. I'll also see about getting a proper EMS and fuel system since I'm not a fan of boost dependent FMU's.
Old Dec 22, 2004 | 08:03 AM
PHOBIA's Avatar
well,um buying a whole kit is going to cost you twice as much.i bought every thing from people on here or ebay.all the same names just differnt parts,ive spent about $1500 and all i need know is gauges and manifold and a fmu unit,given i didnt have to buy the vafc controller but thats part of the $1500 i spent.not bad considering its parts from tial greddy turbonetics and so on.
Old Dec 22, 2004 | 08:07 AM
PHOBIA's Avatar
</TD></TR></TABLE>why did you have to get a half sized radiator? ive seen the same setups with the sttock radiator?damn i really hope this isnt one more thing to add to the "need to buy list"witch is taking forever.also what brand did you end up getting?
Old Dec 22, 2004 | 08:15 AM
slowpokesi's Avatar
Default Re: (PHOBIA)
you can seee how much the compressor sticks out, there is no way for a full size stock radiator to fit, i ended up using a 92-95 civic radiator instead, im also using a back door endtank intercooler, and because of that, if you had a full size radiator you piping would have no where to go.
yes kits are more expensive, but its alot easier, getting a bunch of piping fabbed up would of cost me 3 or 4 hundred bucks with all the bends it would take i would also lose efficiency, with this setup the path is really direct and more efficient!
Old Dec 22, 2004 | 12:17 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">you can seee how much the compressor sticks out, there is no way for a full size stock radiator to fit, i ended up using a 92-95 civic radiator instead, im also using a back door endtank intercooler, and because of that, if you had a full size radiator you piping would have no where to go.</TD></TR></TABLE>
Hey meng,
I had another question for you about your rad. Did you just use a OEM EG radiator or did you get a fluidyne or Koyo EG rad? I'm probably gonna buy a FR traction bar, and an EG radiator, but I dont know if I wanna go with an OEM or a fluidyne/koyo half-rad (if they even make half rads).
TIA
Old Dec 22, 2004 | 01:00 PM
slowpokesi's Avatar
thats a oem radiator, if your going to go bling call fullrace because the bling ones wont fit on there bars, theyre making a special raditor for the crx, or thats what they told me
Old Dec 22, 2004 | 02:34 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">thats a oem radiator, if your going to go bling call fullrace because the bling ones wont fit on there bars, theyre making a special raditor for the crx, or thats what they told me</TD></TR></TABLE>
I'll be sure to mention to FR that I'm planning on installing an EG radiator. I think I saw on one of FR's posts in the sponsors marketplace that he now has tractions bars for full size and halfsize rads. I'll ask them though just to be sure.
Thanks
Old Dec 23, 2004 | 09:19 AM
BlueShadow's Avatar
heya slowpokesi,
I just bought the revhard kit and I am kinda psyched. I have a GSR swap so I asked for the T04E 57 trim compressor, and a T3 with a 0.63 A/R. I'll probably use the FMU that comes with the RH kit for a while and just boost around 7 PSI.
I'm thinking that the only other things that I'll have to look into getting is a catchcan, ignition, battery relocation kit, FR trac-bar, EG rad, and a couple of other things. I guess I'll be hanging out in the FI forum a lot more now.
JoeDaSoto
Sep 22, 2006 06:22 PM
bseriesboosted
Nov 22, 2003 09:12 PM
panthegoatgod
Aug 28, 2003 12:34 PM
Fatty_1775
Oct 8, 2002 06:47 PM
ZeRo
Feb 19, 2002 11:43 AM
