question bout tires?
ive got about the same drop on my springs but 40/16, a bit lower pro. and i never rub from hittin bumps or anythin like that. dont know about 215's though, if i were u i wouldnt buy them if you havent already!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by picman »</TD></TR><TR><TD CLASS="quote">will 215/45/16 rub on my 96 gsr? my car is lowered on neuspeed sport springs.</TD></TR></TABLE>
They probably wont! But if your going pure street you should get BFG Drag Radials!
215/45/16 would be too tall as well. 205/45/16 is almsot perfect with stock diameter.
Run a 215/40/16 if you want the additional tread width. It should help with rubbing as well, since the total diameter is slightly smaller than stock, but only by about 1/2 inch.
But really, a wider tire doesn't give you any more traction, unless they change to a softer compound between the 205 and 215 sizes.
pdiggitydogg
49
May 15, 2004 06:15 PM
