FS: Turbosmart E-boost (EBC)
Turbosmart E-boost
The e-Boost is the worlds first re-programmable boost controller utilizing FLASH memory technology, making it compatible with future software upgrades, meaning your e-Boost will never be out-dated. The e-Boost is more than just the best performing electronic boost controller, it is a complete boost management system, making Turbosmart a world leader in boost control systems. This revolutionary product is loaded with features, squeezed into a package small enough to fit in the palm of your hand.
Features include:
*16 bit RISC based FLASH memory CPU – faster and smoother boost response
*Programmable gate pressure function to totally eliminate wastegate creep.
*3 internally or externally activated and individually programmable boost set points.
*High accuracy boost and vacuum display, readout accurate to within +/- 0.5% of full scale, boost gauge no longer required.
*Readout can be tailored to suit your needs – display can be configured in KPA, Bar or PSI.
*Easy to read seven segment display with programmable bar graph and glow in the dark buttons.
*Programmable auxiliary output – e.g. water spray control, water/methanol injection, boost light.
*Programmable audible warning alarm – excellent for over-boost warning or full boost confirmation.
*Peak hold/Max Boost recall function.
*66mm in diameter 55mm long. Suitable for Panel mounting, or in any 2 5/8 inch gauge pod or pillar mounting system.
Honda-tech previous "review"/opinions"' https://honda-tech.com/zerothread?id=997071
PM or call us at 800-959-3193 for pricing.
Modified by Nonstop at 10:46 AM 12/18/2004
Features include:
Wayne,
Great deal on the E-boost. It was a pleasure talking to you over the phone, sorry for keeping you at the office so late. Fantastic customer service.
