Turbo Manifold Materials and Size
Old Dec 6, 2004 | 07:26 PM
rhdune16's Avatar
Default Turbo Manifold Materials and Size
Well I am looking to make my own manifold now cause all the f22 manifolds out there suck. So I ran a search and I found one of my answers but not to all of them. I know I should use sa40 stainless steel but what should be the diameter of the tubing? I don't know that. Also where can I find a F22b flange and a small collector with a t3 flange for the manifold. I am thinking about cutting and marking up everything then taking it to a muffler shop and have them weld it. Also I would need a 38mm tial flange.
Here are some pics of a guy (fknslmd) from accordinglydone.com that made his own f22b manifold. I want mine to somewhat look like this. Any help will be appreciated. Thanks
Old Dec 6, 2004 | 07:30 PM
ExploitedRacing-HR's Avatar
I carry that flange with the two center ports that are close to each other, right now its listed at the F23
Old Dec 6, 2004 | 07:33 PM
rhdune16's Avatar
Which flange are you talking about. The second pic?
Old Dec 6, 2004 | 08:29 PM
fknslmd's Avatar
Default Re: (rhdune16)
the mcmaster.com part number for the stainless elbows is 45605k515. your going to need 15 of em to build the manfiold i did in the pics. i got the collector precut from legendboy on here, dont bother trying to cut one yourself just get it from him!
and be prepared to spend lots of time tinkering with that thing to get it to all fit together. if you want different angle pics of mine let me know.
damn brian, i wish i knew you had that head flange in stainless, i ended up using mild steel with everything else 304.
Old Dec 6, 2004 | 08:51 PM
No i carry the honda flange for the F series engine with the two center ports that are close to each other, On my website there listed as "F23" flange
Old Dec 6, 2004 | 09:17 PM
rhdune16's Avatar
Default Re: (fknslmd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknslmd &raquo;</TD></TR><TR><TD CLASS="quote">the mcmaster.com part number for the stainless elbows is 45605k515. your going to need 15 of em to build the manfiold i did in the pics. i got the collector precut from legendboy on here, dont bother trying to cut one yourself just get it from him!
Sure any pics would help. Also why would I need 15 of them. Isn't that a lot. I was wondering if you could get all the parts for me and cut them to your specs and I'll pay for the parts and your time. If not, it's cool. What did you do about the wastegate tube and flange. Also how much do you guys think it'll cost to weld if everything is lined up?
Old Dec 6, 2004 | 09:19 PM
rhdune16's Avatar
Also how much did all the parts set you back including everything needed for the setup except the welding.
Old Dec 7, 2004 | 12:31 AM
civicbynature's Avatar
I have two questions ? First off from the pics those are some sweet eye candy good fab. but, In the pics you have then installed are they welded or just tacked to see how it would look and fitt. Secondly ........ have you tried them yet. They look close to the hood will the heat effect the outer hood paint?
Old Dec 7, 2004 | 12:47 PM
fknslmd's Avatar
Default Re: (civicbynature)
my bad i used 14 of the elbows, i bought an extra one in case i messed up on a cut. heres a breakdown of the material costs
head flange- mild steel $60
stainless elbows- $90
precut stainless collector-$65
stainless t3 flange-$25
stainless wastegate flange-$25
im sure you could find better prices on the flanges but i'm not a bargain shopper so i didnt look around.
like i said on AD, i may do a few more of these but not until mine has been tested by me. i wont take the chance of selling some piece of **** i made to somebody else. i wont be using mine for a few months due to having my motor built and winters here anyways. as for selling the pieces precut, you only really need to cut the bottom pieces for the 2/3 runners. other than that the elbows pretty much fit the way they are. ill try to get some finished pics up here pretty soon with it all welded.
civicbynature, yeah in the pics if was just tacked together to check for clearance issues. in the pictures it does look like it sits high but it really doesnt. i checked hood clearance and it was fine.
Old Dec 7, 2004 | 05:25 PM
rhdune16's Avatar
Thanks a lot man. Pics will surely help. Do you know how much it'll cost me to get it all welded? Anyways, I'll for sure hit you up when I need some help. O yeah are there any hood clearance issues. I have a CF hood.
Old Dec 8, 2004 | 05:04 AM
ok so even if it clears the hood and it does shut and everything does the heat radiating from it effect the the hood or the paint like discoloring or warpage weather it has a factory hood or aftermarket..
Old Dec 8, 2004 | 01:14 PM
fknslmd's Avatar
i'm not sure how much someone would charge to weld something like that but i'm guessing around a hundred bucks or so.
i didnt have any hood clearance problems with mine, the highest part of the manifold was about even with the valve cover. since the motor leans back a little bit i had to make the 2/3 runners a little lower as you can see in the pic. i have a cf hood too with a plastic underside so we'll see what happens when i eventually get it together.
Old Dec 10, 2004 | 05:53 AM
right on man, when you try it out i'd like too know. that's that kind i'm lookin into but with a new paint job i fear the worst.
Old Dec 11, 2004 | 05:29 AM
Terrabomb's Avatar
https://honda-tech.com/zerothread?id=956666
Old Dec 11, 2004 | 09:39 AM
xerox445's Avatar
Default Re: (Terrabomb)
if you go 2 a "muffler" shop, they are probly going to pull out the ole MIG welder and go 2 town...if you going 2 pay for something, at least have someone decent 2 TIG it. In my experience, welding was not something you need 2 know how to do to work at a muffler shop...you just kind of learn how 2 work it, most guys arent trained at all.
Old Dec 11, 2004 | 09:45 AM
fknslmd's Avatar
Default Re: (xerox445)
agreed! i work with a guy that previously worked and midas, he can mig pretty good but has never used a tig in his life.
Old Dec 11, 2004 | 12:35 PM
rocketlude's Avatar
TIG welding that stuff up is pretty time consuming. it has to all be cleaned and de greased. Then you have to clamp it to make sure it doesn't warp. I would say a person would have 3-4 hrs welding something like that up. If it gets too hot it will warp all over the place so you have to give it time to cool. I would expect to pay atleast 200 for a professional tig weld in stainless. $70 per hour is pretty common for that type of work.
Old Dec 11, 2004 | 04:03 PM
JDMCRX's Avatar
Default Re: (rocketlude)
Man looks pretty good.
Old Dec 11, 2004 | 04:30 PM
5thgencivic's Avatar
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Man looks pretty good.</TD></TR></TABLE>
Sure does. Nice work.
Old Dec 11, 2004 | 04:34 PM
rhdune16's Avatar
That isn't my manifold. It's fknslmd's manifold. I agree, it is a badass manifold for the accord
Old Dec 24, 2004 | 12:07 AM
rhdune16's Avatar
Bump cause i would like to see some new pics of fknslmd's manifold...lol, if possible
Old Dec 24, 2004 | 06:21 AM
onefstek's Avatar
my friend need one for his H22 turbo prelude, but he wants to buy one.
I told him I could make him one but he seemed NOT interested, so I not going to do it for him, but instead im gona make one for my gsr.
I did make one for my girls D16y8 powered civic and it turned out ok. 98ctr
Old Dec 24, 2004 | 07:06 AM
fknslmd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdune16 &raquo;</TD></TR><TR><TD CLASS="quote">Bump cause i would like to see some new pics of fknslmd's manifold...lol, if possible</TD></TR></TABLE>
hopefully i will have it back pretty soon to get some pics, it's being welded by a friend of mine. did you get yout materials yet and start playing around with it??
Old Dec 24, 2004 | 07:13 AM
boostedfe3's Avatar
Default Re: Turbo Manifold Materials and Size (rhdune16)
Where did you get the pre-cut collector pipes for 65 dollars? Any help is appreciated.
Old Dec 24, 2004 | 07:16 AM
fknslmd's Avatar
Default Re: Turbo Manifold Materials and Size (boostedfe3)
i got it from legendboy on here, he'll hook you up.
