which one is better SRP or CP
<U>cp</U>
CP ACURA B18A/B:81.5mm-10.5:1
CP ACURA B18A/B:81.5mm-9:1
<U>srp</U>
ACURA 1.8LS(B18A/B):81.5mm/10.5:1
ACURA 1.8LS(B18A/B):81.5mm/9.2:1
having to bore out to 81.5 and was wondering which was the better route to go. with the 9:1 and the 9:2:1 i could go with cometic head gasket. give input. any will be helpful!!!
<U>srp</U>
From: Salt Lake City, Chicago at heart, UT or IL, USA
YOu definately would want more compression if you wanna do all motor. At least get it to 10 ish, if not even higher.
ok so 10:5:1 but should i go srp or cp pistons? srp are a little cheaper but i didnt know if there was much of a difference since both are same compression ratio. is it worth it to go cp instead srp?
blackeg
Sep 14, 2005 08:13 AM
jap-spec
Jan 16, 2003 09:35 PM
