How do YOU remove your B-pipe from your car?
Old Jan 1, 2002 | 09:50 PM
Toda Party's Avatar
Default How do YOU remove your B-pipe from your car?
A couple weeks ago, since I had nothing better to do, and since I was curious, I unbolted the cat and ran open header for a couple hours...wow that was loud.
Anyway, I got the 2 bolts with the springs off pretty easily, but the other end of the cat, where its the 3-bolt flange....how the HELL do you guys get that top bolt off ? I got the 2 bottom left and right bolts off pretty easily...
I ended up dropping the whole B pipe off the hangers...however, I did not have ratchet extensions...but now i do so it might be easier if i ever for some unknown reason decide to do it again....
Old Jan 1, 2002 | 10:04 PM
spoonek4's Avatar
Default Re: How do YOU remove your B-pipe from your car? (Toda Party)
Yeah man u need 3/8 drive ratchet, pretty long extension and a deep socket to do the job if u don't take the center hanger bushing off. I always spray a bit WD40 before I take those nuts and bolts off.
Old Jan 1, 2002 | 10:11 PM
Bbasso's Avatar
HAHAHAHAHAHA LOUD?
Old Jan 1, 2002 | 10:12 PM
Bbasso's Avatar
NA...
Old Jan 1, 2002 | 10:20 PM
EG8R's Avatar
Default Re: How do YOU remove your B-pipe from your car? (Bbasso)
You sure it was loud? I ran my engine straight off the head for a few minutes. Saw some nice flames hehehehe
Old Jan 2, 2002 | 12:06 AM
sgT's Avatar
sgT
Drop the b-pipe and hit the top one with my impact.
The best way to do it.
Old Jan 2, 2002 | 12:44 AM
Toda Party's Avatar
Default Re: How do YOU remove your B-pipe from your car? (sgT)
I wish i had an air compressor
Old Jan 2, 2002 | 12:49 AM
Hybrid ctr's Avatar
I remember when I helped a friend put a testpipe on
we dropped the b-pipe but couldn't get the cat off
we spent couple hours on it until we finally gave up
the next day he bought an air compressor and got the bolts
off and bolted everything back up in 5 minutes
Old Jan 2, 2002 | 05:18 AM
sackdz's Avatar
Default Re: How do YOU remove your B-pipe from your car? (Hybrid ctr)
AIR TOOLS =
Do you guys leave on all your heatshields? I have just the cat one off right now.
Old Jan 2, 2002 | 06:17 AM
travis's Avatar
Default Re: How do YOU remove your B-pipe from your car? (sackdz)
Without the benefit of air tools, we had to remove the hangers and allow the b pipe to hang. Then we worked at it with a 3/8 driver and extension for 10 minutes at the most before it gave. Do the reverse for install.
Old Jan 2, 2002 | 09:18 AM
JPP's Avatar
JPP
Damn you are remending me some bad memories.
When I installed my header, it took me a good 3 hours to remove that f*** top bolt. It was so rusted that I finally had to cut the nut off and pop the rest of the bolt out. I reinstalled everything with stainless steel nuts and bolts and now it is much easier to remove with a small key and a ratchet.
Everytime I work on my car there is always a little insignificant bolt or hose that just wont come off and that I have to curse at for an hour. That's the beauty of saving money on labor
Old Jan 2, 2002 | 03:06 PM
Toda Party's Avatar
Default Re: How do YOU remove your B-pipe from your car? (JPP)
haha, yeah as much as its annoying, i love doing my own work
sackdz - i left the bottom one off, but my parents were interrogating me, since they thought it was some important part of the car or something, so i ended up putting it back on
Old Jan 2, 2002 | 04:05 PM
Teepo's Avatar
i think their 14 mm bolts ...3 on the cat 2 on the rear section
Acidcrakker
Mar 3, 2008 08:46 PM
Acidcrakker
Oct 12, 2007 06:19 AM
kornerk12
Nov 21, 2006 09:59 PM
slammedteg
Mar 15, 2004 04:48 PM
jabenne
Apr 24, 2002 03:57 PM
