Does anyone know why the door beeper will stick on?
Old Dec 6, 2004 | 04:48 PM
MattP's Avatar
Default Does anyone know why the door beeper will stick on?
If I open the door and close it a few moments later, the warning beeper will stay on. The only solution I have found is to turn off, and restart the engine. From the search, this seems to be a common problem. In fact, my old Civic Si had it as well.
What causes this problem? Is there a separate door open/close switch from the one for the dome light? I have unplugged my seat belt warning sensors, but that only gets rid of the belt related beeping.
Is there a solution that doesn't involve removing all of the warning beeper circuitry?
Old Dec 6, 2004 | 05:06 PM
MattP's Avatar
Default Re: Does anyone know why the door beeper will stick on? (MattP)
Dug out my helms manual, there's 10 pages of troubleshooting just for the hatchback, and probably twice that for the sedan. Looks like it's connected to the seatbelt tensioning system. I'll try and post the relevant pages.
Old Dec 6, 2004 | 05:17 PM
mr. carpenter's Avatar
mine does the same thing. i just push in the clutch and turn the car off and on. if you fix it let me know.
Old Dec 6, 2004 | 05:26 PM
GreenMachineRex's Avatar
Default Re: Does anyone know why the door beeper will stick on? (mr. carpenter)
if i recall correctly. where the mirror is, if its an si, you can pop off where that cover is (where that little light up set-up is) and there is a plug in there. unplug it. should do the trick
Old Dec 6, 2004 | 05:32 PM
MattP's Avatar
Default Re: Does anyone know why the door beeper will stick on? (GreenMachineRex)
That's what I would do, but after reading the service manual, if the door beeper is on, it means the seat belt tensioners will not trigger. I'd rather not find out the hard way that the belt tensioners aren't working.
I will do the tests in the manual this weekend, and I'll let everyone know how it turns out. (Oh, how I hate removing door panels.)
Modified by MattP at 10:38 PM 12/6/2004
Old Dec 6, 2004 | 05:37 PM
Bee17hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">if i recall correctly. where the mirror is, if its an si, you can pop off where that cover is (where that little light up set-up is) and there is a plug in there. unplug it. should do the trick </TD></TR></TABLE> thats what i did on mine
Old Dec 6, 2004 | 06:21 PM
Kasper.'s Avatar
Default Re: Does anyone know why the door beeper will stick on? (Bee17hatch)
lube the door ajar switches, they are gumming up or you've got high resistance in your wiring for the switches.....even after the door is closed they read open happens on alot of vehicles.....lube/replace the switches, they will start working correctly again.
austinramsay
Nov 16, 2016 01:02 AM
Garry_90Civic
Jul 3, 2014 04:57 AM
themikewoo
Sep 30, 2011 03:19 AM
speedtrash2
Feb 14, 2007 07:01 AM
green91
May 18, 2005 05:13 PM
