h22 swap questions.
normally when it comes to h22 swap questions, the response "search" is expected, so before posting this i spent the past few days doing just that.
however, im still confused on a few things. i am planning a swap, and want to make sure i have all my bases covered.
the h22 will be going into a del sol... i think i got some things straight but please correct me if i am wrong.
A)
the swap is the same as the eg hatch, more or less.
i plan on using the hasport mount kit in the swap.. its the best, right?
B)
i researched as much as possible, but i am still confused about the resistor box, and why it is needed. anyone care to shed some light on that?
C)
i can use the prelude OR accord shift linkage, correct? any how-to's for the install? do i need any extra pieces besides the shifter, the base, and the cables?
D)
what can i remove to clean up the bay... the black box thing under the manifold (not pcv) that is used for the 2nd butterfly.. .can **** like that be removed? what are the minimal vacume hoses needed?
E)
with a fullsize koyo/fluidyne radiator- what radiator hoses do i need to use? or should i go for the ghetto look and get the universal flexible kind?
A)
B)
C)
D)
E)
The resistor box is needed for the type of injectors it uses, I suppose you could swap in standard 240 cc b series injectors and be okay until you upped the power considerably
the del sol is an eg
You can use a neoprene expansion plug appropriately sized ( they have them at ACE hardware ect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sans »</TD></TR><TR><TD CLASS="quote">The resistor box is needed for the type of injectors it uses, I suppose you could swap in standard 240 cc b series injectors and be okay until you upped the power considerably
You can use a neoprene expansion plug appropriately sized ( they have them at ACE hardware ect</TD></TR></TABLE>
thanks. i plan on keeping the motor stock, minus i/h/e for a while.. would my d15b injectors work, or are they too small?
It also works to post in the Eg/Del Sol forum
I concur that the mounts will work fine.
What type Del Slow do you have? Please dont say you have a B16a
If you do i'll buy your engine
