b16 mounts?
Old Dec 6, 2004 | 04:04 PM
rdawg000's Avatar
Default b16 mounts?
i have a 2000 civic lx 4 door, swapping a b16 94 in car. Do i use the factory mounts, or use the mounts from the motor and the b16 donor car?
Old Dec 6, 2004 | 05:26 PM
Kataku2K3's Avatar
Default Re: b16 mounts? (rdawg000)
You'll need the rear motor mount bracket and the driver side upper mount (the one that bolts to the block) from a '99-2000 Si. The front lowers can be from any '94-2001 Teg, DOHC VTEC Del Sol, or '99-2000 Si. You can use your current upper tranny mount off your D16 and also the driver side top apron (piece that attaches the chassis mount to the motor). It's pretty simple.
CRX30436
Mar 17, 2008 03:23 PM
jdm4life!
Jul 30, 2005 09:53 PM
civic_freak
12
Jul 6, 2004 06:41 PM
NCHATCH
May 26, 2003 02:23 PM
