Gauge Cluster light bulb question
I want to replace the bulbs in my 92-95 gauge cluster with some LEDs. http://www.superbrightleds.com has LEDs that fit into the large size bulb (the 74 size) but not for the 24 size. however I was informed by the guys who run the site that if i can find the dimensions to the 24 size bulb they may be able to help me out.
so do any of you guys got the size specs for the 24 size bulb (the small one) that goes in your gauge cluster?
There is a DIY thread out there that goes through painting the existing bulbs and taking apart the complete cluster, gauge and heating controls.
If you do Leds then you have to lodify the number of bulbs that you have, because if you dnt then there will be dim lighting in alot of places. Do a search someone did a write up on this.
https://honda-tech.com/zerothread?id=987498 Heres a link
